1. MerpsMom's Avatar
    Is there a way to revert to more options in the pulldown menu for needed buttons? My Note 3 had a longer list of those you could highlight for use, but my Note 5 seems to limit the selection and requires a swipe to the left.
    MM
    03-18-2016 06:38 PM
  2. foxisbubba#AC's Avatar
    MM
    You can edit by touching the gear, or use 2 fingers to pull down and see all.
    03-18-2016 08:48 PM
  3. TJA3500's Avatar
    Pull down the notifications and swipe the row of icons to the right for more. Touch the down arrow next to the gear icon then press edit to add the ones you want.
    03-18-2016 08:57 PM
  4. debdroid1a's Avatar
    You have only 10 choices to see at a time. Swipe left and right.
    Posted via the *Note 5*
    03-19-2016 11:38 AM
  5. droidtgray's Avatar
    Swype down from the top with two fingers.
    03-20-2016 09:30 AM
  6. MerpsMom's Avatar
    Thanx, and I did figure the best way is to hit the EDIT next to the gear in the upper-right-hand corner. My old Note 3 had the two-fingers-down trick, but my 5 doesn't. Not a big deal, but nice to have the options back for seeing all available.
    03-23-2016 05:37 PM
  7. DsM's Avatar
    My Verizon Note 5 does not require a 2 finger swipe to reveal all the options. Swipe once with one finger and I get 5 boxes. Swipe left I get 5 more. Swipe down with 1 finger and I get them all.
    03-29-2016 02:20 AM
  8. DsM's Avatar
    Ok, i misunderstood. The 2 finger swipe initiates all the options immediately. Sorry.
    03-29-2016 02:22 AM
  1. Modded a standard USB cable to work for the Martian Notifier
    By 312MotoGus in forum Martian Smartwatches
    Last Post: 12-05-2016, 06:14 AM
  2. Can't talk on the phone without apps opening help
    Last Post: 03-18-2016, 11:36 PM
  3. Replies: 1
    Last Post: 03-18-2016, 11:33 PM
  4. Replies: 3
    Last Post: 03-18-2016, 09:56 PM
  5. S7 Edge - Easy Tweak For More Screen Space
    By Almeuit in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 05:20 PM
