1. hbstuhr's Avatar
    Does anyone know if the Samsung Galaxy S5 case will fit comfortably on the Samsung Galaxy Note 5 phone? If not, is there an S version case that will work on the Note 5 phone?
    03-24-2016 10:39 AM
  2. jlost's Avatar
    No you have to get a different case for a different phone.
    debdroid1a likes this.
    03-24-2016 10:40 AM
  3. Kendahl Titcomb's Avatar
    There are tons of cases on Amazon by Spigen that are all with shipping still around $10-15. No S series cases will fit the larger Note series phones. Even the larger S6 edge + still does not fit the Note series.
    03-24-2016 10:56 AM
  4. chazglenn3's Avatar
    I assume you mean the S-View case. No, the case from the S5 will not fit the Note 5. Yes, Samsung sells one for the Note 5.
    03-24-2016 10:56 AM
  5. Racer11's Avatar
    Ebay has a ton of cases
    03-26-2016 12:17 AM
  1. How can I change the width of my keyboard on my S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 08-20-2016, 02:41 PM
  2. Replies: 2
    Last Post: 05-08-2016, 12:20 AM
  3. Does the S7 Edge camera have dual flash?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-27-2016, 12:29 AM
  4. Where is menu button location on a Note 5?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 03-24-2016, 07:37 PM
  5. When will the S7 Edge be available in Brazil?
    Last Post: 03-24-2016, 09:58 AM
