1. Oscar Maradiaga's Avatar
    How to get rid of this ?How do I get rid of this volume warning when making volume go higher? [Note 5]-screenshot_20160324-220436.jpg
    03-25-2016 08:00 AM
  2. TJA3500's Avatar
    You have to be rooted or If you install Tasker, you can use a plugin called autoinput.
    03-25-2016 08:05 AM
  3. slackerjack's Avatar
    Or just suck it up...it only happens once after a fresh reboot. Hardly a reason to root
    03-25-2016 08:37 AM
  4. novice's Avatar
    It's not a massive inconvenience; as pointed out it occurs once per reboot.
    Nonetheless, is there a box to check using Package Disabler Pro?
    03-26-2016 09:17 PM
  5. TheMatrix31's Avatar
    It would be great to disable this nonsense.
    03-26-2016 11:30 PM
  6. bbqwings2's Avatar
    Actually it happens every time I plug in headphones, not once a reboot. I like it though, because for me it's pretty much if I have it above that level then people can hear my music in public.
    From my Note 5 paired with my larger Asus Zenwatch 2
    03-27-2016 12:23 PM
  7. Soylent_Green's Avatar
    It is annoying yes but you get over it.
    03-27-2016 02:14 PM
  8. TheMatrix31's Avatar
    It sucks when you have to bump the volume on the phone using Spotify while driving so that it comes in louder on Bluetooth and you have to fumble around because of this stupid message that you forgot exists.
    acles003 likes this.
    03-27-2016 07:36 PM
  9. homestead's Avatar
    I also find this a nuisance every time I begin to listen to podcasts over Bluetooth in the car.
    TheMatrix31 likes this.
    03-27-2016 08:17 PM
  10. DsM's Avatar
    I'm not having this problem once I adjust the ridiculous volume limiter first thing in the morning while I'm shaving I never have to fool with it again. And I plug in earphones and blue tooth devices at least 10 times a day. Have no solution for your problem though.
    Again, I'm wondering if Package Disabler Pro has a box that would disable this function. I don't have the technical expertise to sort through all the possibilities.
    03-29-2016 12:46 AM
  1. Galaxy S7 Volume Button Won't Let Me Mute The Phone
    Last Post: 03-25-2019, 01:36 PM
  2. Replies: 6
    Last Post: 03-30-2016, 07:07 AM
  3. How To Recovered Deleted SMS/Text Messages On Your Android Phone!
    By isayata in forum General News & Discussion
    Last Post: 03-29-2016, 04:37 PM
  4. How do I type an equal sign on a Droid 4G?
    By AC Question in forum Motorola Droid
    Last Post: 03-29-2016, 01:01 AM
  5. Can a note 4 back cover fit a note edge?
    Last Post: 03-29-2016, 12:56 AM
