1. Hayat55's Avatar
    Hi, for some reason my Note 5's battery life is only 12hours and 50mins from full charge. I have to charge it twice a day. Before I never had to charge it twice a day - only once a day. My note 5 is the SM-N9208 (Dual Sim 64GB Silver), Android Marshmallow has not been released for it yet. Is there something wrong with my battery? I bought the phone from an eBay UK seller and PayPal's buyer protection period ends for me today midnight so I need some advice quick. In addition, the fast charging seems to have stopped working with my charger - I am using a UK travel adapter because the fast charger is 2 pin. I appreciate any suggestions on how to fix this. Thanks!
    03-27-2016 01:00 PM
  2. cogic740's Avatar
    Same here. Removed couple of apps and a ring tone, which helped a little. Battery drain started with the download of February security patch.
    03-27-2016 01:07 PM
  3. Hayat55's Avatar
    I downloaded a security patch yesterday. So should I not worry then??? My 6 month buyer protection ends today with PayPal?!?!
    03-27-2016 01:40 PM
  4. blackhemi4x4's Avatar
    See if it gets better by booting in safe mode.
    03-27-2016 05:06 PM
  5. novice's Avatar
    Sorry, not enough info. What does your battery usage chart show under settings. For a quick and dirty possible fix do a factory reset asap.
    03-27-2016 08:17 PM
  6. Hayat55's Avatar
    How do I boot in safe mode?
    03-28-2016 07:39 AM
  7. Hayat55's Avatar
    I removed some apps that I didn't need and now my estimated time has risen to 15hrs after a full charge and fast charging seems to be working again. If I buy the aukey fast/turbo charger then will it fast charge all the time instead of sometimes like the samsung charger?
    Here is the screenshot when my battery is at 33% (Screen On time is 2hrs and 19 mins)
    03-28-2016 07:39 AM
  8. blackhemi4x4's Avatar
    Safe mode
    Turn the device off.
    Press and hold the*Power*key.
    When 'Samsung Galaxy Note5' appears on the screen, release the*Power*key.
    Immediately after releasing the Power key, press and hold the*Volume down*key.
    Continue to hold the Volume down key until the device finishes restarting.
    Safe mode*will display in the bottom left corner of the screen.
    Release the*Volume down*key when you see*Safe Mode.
    03-28-2016 09:05 AM
  9. Hayat55's Avatar
    Safe mode
    Okay, thanks! Will try this after my next full charge
    blackhemi4x4 likes this.
    03-28-2016 12:35 PM
  10. DsM's Avatar
    Your screen, Facebook and Android System usage seem well within normal limits. Maybe your problem is solved.
    03-29-2016 12:04 AM
  11. Hayat55's Avatar
    I'm getting 15hrs use currently. Is this normal? I thought it should be about 20hrs??
    03-29-2016 08:11 AM
  12. Trees's Avatar
    15hrs use is fine, 20hrs could be achieved; but that depends on many factors like Screen on Time, apps actively used, cell signal, Auto brightness level...
    03-30-2016 07:21 AM
  1. Help!! New 6.0 Marshmallow update causing apps to close.
    By MrsT15 in forum Samsung Galaxy Note 4
    Last Post: 03-28-2016, 12:29 PM
  2. help with moto g2 wont start
    By surjeet marwah in forum Moto G (2014)
    Last Post: 03-27-2016, 06:41 PM
  3. Can you help me?
    By Armohide11 in forum General Help and How To
    Last Post: 03-27-2016, 06:16 PM
  4. URGENT! weird behaviour Android M. pls help
    By emjey in forum Android 6.0 Marshmallow
    Last Post: 03-27-2016, 02:33 PM
  5. [CHUP.I] Need a review for a friendly reminder camera- app
    By Thuy Duong Nguyen in forum Android Apps
    Last Post: 03-27-2016, 09:46 AM
