1. BamaMomRollTide's Avatar
    I don't have many apps downloaded, the phone is newish, but when texting, sometimes it just freezes while trying to input a letter....I have to wait for it to unfreeze to keep going. What's up with that?
    03-30-2016 06:00 AM
  2. missy8787's Avatar
    My note 5 does that sometimes too but it's only when I'm in an area in the house that doesn't have good reception when I have full bars it's fine.
    03-30-2016 07:54 AM
  3. Jamie Wooten's Avatar
    I sometimes have mine freeze up when writing as well. I also experience some lag in the keyboard. Not really sure what the problem is or if there's a fix. I'll watch the thread.
    BamaMomRollTide likes this.
    03-30-2016 08:12 AM
  4. novice's Avatar
    Kinda difficult to tell without knowing what keyboard is being used. If using the included Samsung keyboard I would experiment with an alternative like SwiftKey. Then there's the next question involving what messenger app is being deployed.
    03-31-2016 04:32 PM
  5. BamaMomRollTide's Avatar
    Can you say more? What is MM?
    04-01-2016 11:30 PM
  6. novice's Avatar
    I'll take a wild guess that MM is Marshmallow. And that KB is keyboard. Don't have the slightest clue what this cryptic posting means.
    04-02-2016 02:54 AM
  7. novice's Avatar
    Not being sarcastic at all. Is the meaning that Marshmallow and not the keyboard is responsible? That's my best guess. But I'm not sure that every poster complaining of this problem is using Marshmallow.
    04-02-2016 01:17 PM
  8. josney's Avatar
    mine would do the same thing until I realized I had a ton of saved text to my GF. It would lag only when I would text her. maybe check to see how many saved messages you have.
    04-02-2016 04:27 PM
  9. trucksmoveamerica#AC's Avatar
    Mine started doing that today, I cleared cache in boot menu and seemed to fix it for now. I'm using MM and Minuum keyboard.
    04-02-2016 09:46 PM
  1. Replies: 2
    Last Post: 04-03-2016, 06:21 PM
  2. Replies: 1
    Last Post: 03-30-2016, 01:36 PM
  3. Replies: 1
    Last Post: 03-30-2016, 01:19 PM
  4. Replies: 1
    Last Post: 03-30-2016, 03:44 AM
  5. Replies: 1
    Last Post: 03-29-2016, 11:18 PM
