1. rkirshner's Avatar
    hello
    may i ask a question about the 3 g version of the gear s2 as it relates to the note 5
    the 3 g version has it own 'phone number"
    can i set up my samsung note 5 such that if a call or text comes to my note 5 it will alert me and i will be able to receive it on my 3g watch even if the watch and phone are miles apart
    thank you
    05-01-2016 11:04 AM
  2. zocster's Avatar
    thank you
    The only way you can set this is to forward your SMS to your number on the watch, not sure how easy that will be to distinguish?
    05-01-2016 11:45 AM
  3. Trees's Avatar
    I have the Gear S, and it's possible to have phone calls and texts sent to the Note 5 show up on the Gear S if the forwarding option is setup. I have not used the Gear S enough remotely to know if replies to SMS show up as the Gear S number, or the Note 5's. Maybe it works differently on the Gear S2, though.
    05-02-2016 06:09 AM
  1. 3g capabilities
    By rkirshner in forum Samsung Gear S2
    Last Post: 02-10-2017, 03:07 PM
  2. Enable HD Voice on Galaxy Note 4
    By Sunun in forum Samsung Galaxy Note 4
    Last Post: 05-03-2016, 06:48 PM
  3. Note 5 issue with SSID
    By Rahim Esmail in forum Samsung Galaxy Note 5
    Last Post: 05-01-2016, 01:14 PM
  4. Software update for Note 3
    By gayanlk3 in forum Ask a Question
    Last Post: 05-01-2016, 11:00 AM
  5. Software unathorized- Galaxy note 4 msg after using kingroot no back up
    By Timothy Leyva in forum Samsung Galaxy Note 4
    Last Post: 05-01-2016, 10:49 AM
