1. faith3935's Avatar
    Hello. I obtained a fast wireless charger which looks like this but somehow when I plug it in and place my AT&T Note 5 on it gives me this. Is it fast wireless charging my phone?
    05-04-2016 12:40 PM
  2. SpookDroid's Avatar
    Probably, yup. Fast Wireless charging isn't the 'normal' Fast Charging that will fill up your phone in 15 minutes for the first 50% (and to my knowledge, the Fast Charging notification only shows up with wired chargers). What Fast Wireless charging does is charge your phone faster than normal wireless charging, but you shouldn't expect the same speeds as a wired Fast Charger (it's actually closer to the standard 2A charger, I think).
    Update: Here you go, they compare all options and you can see the difference in a nifty little graph.
    http://phandroid.com/2015/09/25/sams...ng-comparison/
    05-04-2016 12:58 PM
  3. vader4633's Avatar
    It will say fast wireless charging, not just wireless charging. Make sure you are using the fast charging plug for the wireless charger.
    Posted via the Android Central App with my Note 5
    SpookDroid likes this.
    05-04-2016 04:06 PM
  4. faith3935's Avatar
    Gotcha. I may have to buy one then since White one that I have doesn't work.
    05-05-2016 11:12 AM
  5. isired's Avatar
    You definitely need a fast plug and compatible cable... it's significantly faster than any non-fast wired cable, and not significantly slower than the fast wired cable - if I'm at 60%, it takes like 7 minutes longer to get to full.
    05-06-2016 08:24 AM
  1. My Verizon LG G3 VS985 won't sustain a charge.
    By emeraldleo72 in forum LG G3
    Last Post: 05-14-2016, 11:30 AM
  2. Galaxy tab a 8.0 otg host charging
    By mizery19 in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 05-05-2016, 09:44 AM
  3. When to Re-Charge the Battery
    By jmagid51 in forum Samsung Galaxy Note 4
    Last Post: 05-04-2016, 01:10 PM
  4. what is the charge for locating for my lost phone?
    Last Post: 05-04-2016, 04:14 AM
  5. Replies: 1
    Last Post: 05-04-2016, 02:59 AM
