1. AC Question's Avatar
    Note 5 N9208 dual sim MM update came. I downloaded but unable to install. it goes upto 27% and than collapse and phone restarted. after that we have to again download appx. 1.5 gb data of MM again just install upto 27% and error shows and restart with the old version. I tried it 4 times but unable to instal it. any help will be appreciated. Thanks in advance.
    05-06-2016 02:07 AM
  2. chanchan05's Avatar
    Have you tried doing the update via Kies 3 on a PC?
    05-06-2016 02:14 AM
  3. AD01's Avatar
    I am facing the same issue. Did a complete factory reset. Still facing the same problem.
    Not sure if this is relevant, but got the broken display replaced at Authorised service center of samsung.
    Could not find any solution .
    Thanks.
    10-23-2016 01:08 PM
  4. BuckyBadg's Avatar
    Could actually be a blessing in disguise considering how problematic MM has been to many.
    10-23-2016 01:27 PM
  1. Locked out of phone and then it tries installing a custom OS
    Last Post: 11-24-2018, 10:48 PM
  2. Galaxy s5 sport wifi and mobile data not working
    By knowledge mensah in forum Samsung Galaxy S5
    Last Post: 05-06-2016, 09:38 AM
  3. Replies: 0
    Last Post: 05-06-2016, 12:40 AM
  4. Getting my Note 5 to read .msg files
    Last Post: 05-06-2016, 12:31 AM
  5. phone storage not showing in file manager
    Last Post: 05-05-2016, 11:30 PM
