1. mariataylorxo's Avatar
    My phone died earlier and it wont charge at all. If i get it on, its at 0% and shuts back off. ive tried everything and it wont charge. pls help
    05-08-2016 12:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Make sure you charge it for at least 4-6 hours undisturbed, then try powering back on again. If it doesn't power on, then try a different charging cable and wall plug. If that doesn't help, then either your battery is dead or the charging port is faulty--bring it to a repair shop, or contact Samsung if it's still under warranty.
    Jadedea likes this.
    05-08-2016 01:05 PM
  3. Rukbat's Avatar
    Since it has to precharge first, and most phones don't precharge (Samsung doesn't), I'd leave it charging for 24 hours. Some little charge will leak into the battery and eventually (after hours) it will be charged enough to accept a real charge.
    mariataykorxo, it sounds as if you try to use the last little bit of energy in the battery before charging it. Lithium batteries aren't deep-discharge batteries (which is why you don't see them in cars - you can do that to a lead-acid battery, but not a lithium battery). If you keep discharging it below 40%, you'll kill it quickly ("kill: as in "it won't accept a charge any more and has to be replaced"). They're only $10-$15, but why throw that away when there's no reason to? Charge when it gets down to 40%-50%. (I have an 11 year old battery in my "spare" phone that still works fine. I can get a new one for $4, but why kill a good one?)
    Laura Knotek and beh like this.
    05-08-2016 04:44 PM
  4. Mike_786's Avatar
    I would try a different cable. If that doesn't work try holding the power button and volume down button for like 5 seconds then see if it turns on. If it does just put it on charging and don't mess with it until it hit 100%
    05-10-2016 11:23 PM
  5. Jadedea's Avatar
    i had something similar happen to me. my phone died over night so roughly 6-8 hours of no battery. pluging it into the charger didnt bring up the battery charging icon nor made any sounds that told me the cable was fine. i took my husbands phone and plugged it into the charger to verify it was good, it was. so i just plugged my phone in and came back roughly 2 hours later. the battery icon was showing. i think when the phone has been dead for a while it takes a little time just to charge it to show the basic stuff. hope that helps!
    05-15-2016 09:09 PM
  1. Note 6 release in June - Rumor
    By sqa4life in forum Samsung Galaxy Note 7
    Last Post: 06-16-2016, 07:13 PM
  2. Why won't Location turn off (Galaxy S5)?
    By bekah16 in forum Samsung Galaxy S5
    Last Post: 05-12-2016, 11:27 PM
  3. Should I give up unlimited data on Verizon?
    By kkhanmd in forum Verizon
    Last Post: 05-11-2016, 08:18 PM
  4. Samsung Galaxy S7 Gallery issue
    By ronfc in forum Ask a Question
    Last Post: 05-08-2016, 02:02 AM
  5. Samsung Galaxy note 2
    By sharon 1955 in forum Samsung Galaxy Note 2
    Last Post: 05-08-2016, 12:19 AM
