1. AC Question's Avatar
    The charger worked with poorly made S view cover for a couple weeks then got finicky. I returned it and got the stand Qi wireless charger. Apparently there are certain cases you can wirelessly charge the note 5 with? A case couldn't be thinner than the junky S view case. Maybe I should just go back to plugging it straight to the wall. Frustrating and the guy at Best Buy could have saved this situation by telling me that the case and charger I chose wouldn't work. He's a Samsung rep, but he only works with Samsung.
    05-17-2016 08:58 PM
  2. Rukbat's Avatar
    Almost any non-metallic case should work. I've charged through clear plastic, opaque silicone rubber, leather (probably fake). Put it in a microwave with a cup of water (the cup alongside the case). If the case gets warm it's metallic (or, at least, conductive - same thing as far as wireless charging is concerned. The case is getting the charging current, the phone isn't.)
    05-17-2016 11:23 PM
  3. SugarMouth's Avatar
    My Spigen Rugged Armor case works well with wireless charging.
    Attached Thumbnails Cases for Note 5 compatible with Qi wireless fast charger?-134.jpg
    05-19-2016 08:39 AM
  4. BergerKing's Avatar
    I use the Tech21 Evo case and it works beautifully with the Qi charger. My wife's Otterbox Defender, on the other hand, not so much.
    05-19-2016 08:57 AM
  5. burwil's Avatar
    Poetic Affinity is the case I use and it works on both Qi and garden variety chargers.
    05-19-2016 09:10 AM
  6. mclarryjr's Avatar
    These all work for me, RIngke Slim, UAG, Spigen, and Tumi.
    05-19-2016 11:21 AM
  7. dzstoys's Avatar
    I switch between the Otterbox Defender and the Samsung folio case and can get both to work. The Otterbox requires a much more precise placement than the folio case does and only seems to work on the original fast charger, not the newer stand charger.
    05-19-2016 11:34 AM
  8. Tayloj92's Avatar
    I second the rugged armor case, I've had mine on my phone since I got it in Jan and haven't had a single problem with wireless charging.
    Posted via my AT&T Note 5
    05-19-2016 07:32 PM
  1. Using the stand up Qi charger what is the best app to use at night?
    By Copernikcus in forum Samsung Galaxy Note 5
    Last Post: 05-19-2016, 08:41 PM
  2. Buy the Honor 5x for a buck (if you are lucky)
    By dpham00 in forum Honor 5X
    Last Post: 05-18-2016, 12:18 PM
  3. Replies: 1
    Last Post: 05-17-2016, 11:27 PM
  4. Why don't I have voice for GPS when driving?
    By AC Question in forum Motorola Droid
    Last Post: 05-17-2016, 10:09 PM
