1. flyer13's Avatar
    Hi there,
    I have small issue regarding receiving call via bluetooth with Note 5, I noticed is not working and not ringing while receiving call!!
    the missed call notification is working OK.
    but In the other hand, when I sync the watch with my Iphone 6 plus is working fine 100%.
    what should I do in order to fix this issue?
    thanks
    05-29-2016 01:55 AM
  2. exdrinker's Avatar
    First thing would be to check that the notification for incoming call is turned on. Under notifications-manage notifications, make sure that incoming call is selected. Hopefully it is that easy.
    06-03-2016 09:38 PM
  3. kissdrc1's Avatar
    Hi there,
    thanks
    I'm having the same issue...there is no notification for incoming calls
    06-14-2016 10:36 PM
  4. Tbs1992's Avatar
    Had this happen to mine. Do a light reset on the watch. Did it today and incoming calls work again.
    06-15-2016 09:37 PM
  5. kissdrc1's Avatar
    Tried the light reset, didn't work...maybe I just have the settings wrong, does anyone know what the settings should be to recieve calls on my gear s2...I used to be able to recieve calls on my Gear S when my phone was in another room.
    06-16-2016 08:41 PM
  1. What is the green envelope in contacts mean? [Samsung Note 5]
    By Glinx1 in forum Samsung Galaxy Note 5
    Last Post: 12-21-2016, 08:34 AM
  2. Replies: 1
    Last Post: 05-29-2016, 05:12 AM
  3. How do get onto s voice setting on Samsung Galaxy S4?
    Last Post: 05-28-2016, 09:48 PM
  4. Replies: 0
    Last Post: 05-28-2016, 06:56 PM
  5. Replies: 1
    Last Post: 05-28-2016, 06:32 PM
