1. BMWBig6's Avatar
    For the past week or so, both (Verizon) Note 5 phones in our household display a Smart Switch message prompt after powering up our phones (after unlocking the lock screen). It says something like "Open Smart Switch when this USB device is connected?" and gives an option to cancel, click OK and has a checkbox to "Use by default for this USB device" but no USB device is connected! The last time I used Smart Switch was to transfer all of my personal settings/data from my old Note 3 to Note 5 many months ago. I think I saw several Samsung apps update last week, so maybe that's what caused this issue. Is anybody else seeing the same annoying message? (No matter what option I select---cancel or "OK"--the phone prompts me every time I boot up.) Should I try uninstalling Smart Switch and re-installing?
    06-06-2016 08:28 AM
  2. beh's Avatar
    I too have this on my Note 5. Since I only use Smart Switch when I am setting up a new phone I simply uninstalled it until I set up my new Note 6/7.
    06-06-2016 10:14 AM
  3. wdfrancis58's Avatar
    I'm on Sprint, and have this happen EVERY TIME I reboot my phone! So aggravating! Nothing I choose gets rid of it!
    06-06-2016 03:18 PM
  4. Climb14er's Avatar
    I'm getting this Smart Switch notification as well. Started about a week ago, give or take. I have no idea where it came from. Don't need the reminder!
    06-06-2016 04:56 PM
  5. H3aTeRzz's Avatar
    Hi
    Smart Switch can be uninstalled when you're not using it to transfer data. I would suggest doing that, or installing an app called Package Disabler Pro from the Play Store, and using it to disable smart switch, so you'll still have it for future reference. Just a suggestion.
    You can also try uninstalling/reinstalling.
    Chris
    broncop3t3 likes this.
    06-08-2016 04:52 PM
  1. Replies: 3
    Last Post: 07-29-2016, 02:54 AM
  2. Orange led blinking after replacing battery
    Last Post: 06-07-2016, 06:32 AM
  3. Replies: 0
    Last Post: 06-06-2016, 07:59 AM
  4. Replies: 0
    Last Post: 06-06-2016, 05:19 AM
  5. Replies: 1
    Last Post: 06-06-2016, 02:22 AM
