1. bmetelsky's Avatar
    I followed all instructions pointed to in another thread here regarding using ADB to sideload the marshmallow update downloaded from the AT&T servers.
    I was able to obtain all tools listed, installed ADB, put my phone in recovery mode, selected apply update from ADB, went to the command prompt inside the directory where both ADB and the downloaded file were located, typed in adb sideload and the name of the file including the .zip extension, and it gives the following error: cannot read blahblahblah.zip file. I have searched for solutions and have found none that work. Anybody out there that has done this and gotten the same error and been able to fix it?
    06-11-2016 06:09 PM
  2. Roguefoxx's Avatar
    Have you tried to re-download the MM update again? There's a chance that the one you downloaded is corrupt. Also, you did add the .zip to the end of the actual file itself correct?
    06-11-2016 07:06 PM
  3. bmetelsky's Avatar
    Yes to both questions.
    06-11-2016 08:31 PM
  4. mdoades71's Avatar
    Does your directory name contain spaces? That was causing an error for me.
    06-13-2016 08:26 AM
  5. bmetelsky's Avatar
    No spaces.
    06-14-2016 04:58 PM
  6. bmetelsky's Avatar
    OK - After a week of not trying to update.....I decided to try again. This time I re-downloaded the update file, placed it directly in the same directory as ADB, and did not add the .zip to the file name. It worked like a charm and all is well. I now have Marshmallow on my Samsung Galaxy Note 5 from AT&T.
    06-18-2016 06:51 PM
  1. New power and battery settings with marshmallow.
    By srfoot in forum Samsung Galaxy S5
    Last Post: 06-12-2016, 08:46 AM
  2. Screen black, LED on, factory resets won't work. Help?
    By fdouglas616 in forum Samsung Galaxy S7
    Last Post: 06-11-2016, 08:21 PM
  3. Replies: 0
    Last Post: 06-11-2016, 05:39 PM
  4. Note 4 edge with tmobile is having a micro sd card issue
    Last Post: 06-11-2016, 05:05 PM
  5. Problems with S planner S6 edge+
    By Flora21 in forum Samsung Galaxy S6 edge+
    Last Post: 06-11-2016, 04:10 PM
