Adding fonts?
Barry110
10
Tried 2 font pack downloads from play store for FlipFont. The newly loaded fonts display correctly, and adjust in size, put when I select to install, get an error dialog Font can't be installed. The only font I got to load was tge SamsungSans when selecting add more fonts. So, can you add more fonts (without rooting) or not?
dakini03
117
3
18
Unfortunately the ability to use third party fonts was removed in Marshmallow, assuming that's what you have.
beh
1,378
16
dakini03 is correct, only flipfonts factory installed or gotten from the Samsung store will work after MM.
Barry110
10
Thanks guys, too bad fonts somewhat boring. Never rooted any of my samsung phones...would that then allow it? Recommend rooting phone on scale from 1 (no) to (10) yes?
louee6
Active member
Oct 6, 2012
43
Thats so not true!! I actually have HiFont installed on my before the Marshmallow update and still has my current third party font after update. Thats always the first thing I do is to install a custom font...
beh
1,378
16
Good to know that there seems to be at least one work-around. Hopefully for you, if you have to do a factory reset you will still be able to use the work-around.
louee6
Active member
Oct 6, 2012
43
I haven't done a factory reset after the update. I've been running Marshmallow now for a couple of days without any issues. Hopefully I won't have to factory reset (knocking on wood) lol.
beh
1,378
16
I hope you don't because I believe you are running a "legacy" app that will not work after a reset. But then I have been wrong before :cool:
dllrogers55
261
I was able to still use the third party font until I was tried changing to another font. Then I got the error notification and then none of them worked except stock. Very disappointed. Have you tried changing to another font and back to what you currently use?
Akshay
