1. Rmbrown1964's Avatar
    I updated to use the good lock but I can't use finger print says because of security policy.
    Thanks
    06-27-2016 12:59 AM
  2. dakini03's Avatar
    Thanks
    Are you by chance using Nova Launcher with double tap to lock, or any other screen lock app?
    If so, that's what causes it and that's the message you get. Also on the S7 Edge.
    06-27-2016 02:13 AM
  3. Rmbrown1964's Avatar
    Yes I'm using Nova Launcher. If I double tap on the screen it hides the notification bar. I'm not using any other screen lock just good lock. The nova launcher screen lock is off to.
    Thank you
    06-27-2016 11:42 AM
  4. dakini03's Avatar
    Thank you
    Are you locking your screen by using the Nova swipe down gesture? That will also cause this behavior. Sorry I just noticed you said you're not.
    06-27-2016 12:41 PM
  5. Rmbrown1964's Avatar
    I looked under the gesture and input in Nova Launcher there is no gesture showing lock screen.
    Thank you
    06-27-2016 01:03 PM
  6. dakini03's Avatar
    Thank you
    I'm not sure then. I asked about Nova click to lock and other lock apps, because there's a known issue with them tripping the security policy update and requiring a pin or pattern.
    If your phone operates normally with Touchwiz, requiring only a fingerprint, then you may have an app causing this behavior or a security setting. If you want to further test any possible problem with Nova and don't mind setting it up again, you could clear the cache and data for Nova and see what happens. If you do that, under device administrators in settings turn off Nova.
    I guess you've already cleared the system cache in Recovery and also phone cache Settings/System/Storage, wipe cache. Also of course, a reboot. After a reboot your pin will always be required.
    06-27-2016 03:00 PM
  7. Rmbrown1964's Avatar
    Thank you, for the help I will try what you said.
    dakini03 likes this.
    06-27-2016 03:25 PM
  1. need some help with Lg support
    By dmoz47 in forum LG V10
    Last Post: 10-15-2016, 10:19 AM
  2. can a samsung gear fit be paired with a blackberry passport
    By AC Question in forum Samsung Gear Fit 1 & 2
    Last Post: 06-27-2016, 12:10 PM
  3. Replies: 2
    Last Post: 06-27-2016, 07:03 AM
  4. Lock screen going blank
    Last Post: 06-26-2016, 10:28 PM
  5. Micro SD help! Cant format/write (not write protected)
    Last Post: 06-26-2016, 09:57 PM
