1. Dhanikz's Avatar
    It's weird that the app used for monitoring the battery usage drains a good portion of the battery, at least in my case. I had it installed sometime back and it started draining my battery so I uninstalled it. After a while I installed it again and it worked fine for a while. Then started draining again. Gsam doesnt show up in android's battery usage page. It only appears in gsam details. I haven't really heard any complaints on the net but Is anyone experiencing battery drain from gsam battery monitor.
    07-02-2016 10:01 AM
  2. Trees's Avatar
    I see 0.1% usage from GSam Battery Monitor Pro (within the app itself in the App Usage category). It may not show up in the Settings/Battery usage since it's usage is so low (less than one percent). Have been using GSam for years, and not noticed drain.
    TJA3500 likes this.
    07-03-2016 07:36 AM
  3. Javier P's Avatar
    Same here. Never seen Gsam using more than 0.2-0.3%.
    TJA3500 likes this.
    07-03-2016 07:51 AM
  4. bassplayrguy's Avatar
    Battery monitoring apps always drain battery it seems. Most advise against them unless you are looking for a specific problem but not to use all the time. Better to download as needed then delete.
    07-04-2016 12:33 PM
  1. Google Play Services storage/battery/CPU use problem
    By ts0rge in forum General Help and How To
    Last Post: 07-13-2016, 03:16 PM
  2. GSam on Nexus?
    By deadp1xel in forum Nexus 6P
    Last Post: 07-04-2016, 11:21 PM
  3. Why is wi-fi consuming so much battery power after Marshmallow?
    By isabel95 in forum Samsung Galaxy Note 4
    Last Post: 07-04-2016, 02:36 AM
  4. can battery be removed
    Last Post: 07-02-2016, 04:37 AM
  5. Why wont my tablet display on my monitor??
    By ArtisLee in forum General Help and How To
    Last Post: 07-01-2016, 11:01 PM
