1. vanhoa's Avatar
    Anyone else getting this? These photos are taken with everything on auto
    They are taken in the morning, with light coming through the curtains.
    07-07-2016 01:22 PM
  2. SpookDroid's Avatar
    If you mean the redish spot on the middle, that will usually happen with bright white lights/backgrounds. Is it appearing on all pictures?
    vanhoa likes this.
    07-07-2016 01:53 PM
  3. vanhoa's Avatar
    it appears only when background is white. How can i fix it?
    07-08-2016 10:10 AM
  4. SpookDroid's Avatar
    I'm afraid there is no 'fix'...that's just how the sensor is. You can decrease the red spot and even eliminate it if you manually change settings like exposure or ISO to limit the camera from letting in too much light or you can try sports mode, but this will make your images very dark if there's not enough light (so not ideal for indoor shots). You can toy with the white balance options as well.
    vanhoa likes this.
    07-08-2016 12:01 PM
  5. vanhoa's Avatar
    Thank you!
    07-11-2016 05:59 AM
  6. SpookDroid's Avatar
    No problem! Wish I could have helped more, but sometimes it is what it is.
    07-11-2016 12:27 PM
  1. Galaxy s7- sudden battery drain (Especially when idle)
    By Rachel Voigt in forum Samsung Galaxy S7
    Last Post: 10-07-2017, 11:54 PM
  2. Replies: 3
    Last Post: 07-13-2016, 06:38 AM
  3. Front Camera disappeared
    Last Post: 07-07-2016, 01:35 PM
  4. My Samsung Galaxy Tab A stuck at samsung text
    Last Post: 07-07-2016, 01:02 PM
  5. Replies: 1
    Last Post: 07-07-2016, 11:03 AM
