1. jregan68's Avatar
    Hello,
    Here is my problem. My notification volume will go to the minimum setting all by itself. I can go into the volume controls and move it back up but it will go right back to the minimum volume. I can restart the phone and it will stay up at normal levels but will soon go back to the minimum level. My phone is a sprint note 5 running Marshmallow 6.0.1 (n920pvpu2bpd2). Any help would be appreciated.
    John
    07-13-2016 11:07 PM
  2. jregan68's Avatar
    Can anyone help with this problem?
    07-15-2016 11:55 AM
  3. jregan68's Avatar
    Am I the only one with this problem?
    07-18-2016 11:52 PM
  4. ksmith2263's Avatar
    I had the same issue with my S6. It stopped when I quit using the do not disturb mode at night. Just a thought...
    07-19-2016 07:36 AM
  5. Jay G63's Avatar
    I use do not disturb every night with no volume issues.
    07-19-2016 04:05 PM
  6. Trees's Avatar
    Is the volume key unknowingly being pressed in a bag or pocket?
    07-20-2016 06:22 AM
  7. jregan68's Avatar
    The only volume that is affected is the notification volume. It will randomly go all of the way to minimum. As soon as I try to set it to maximum, it will go right back to minimum right before my eyes. I do not use the do not disturb at all as I need to get calls and notifications at all hours of the day. I have tried everything short of doing a full factory reset.
    07-20-2016 07:12 AM
  8. Trees's Avatar
    I may have run into this problem with an older Note and TouchWiz version. Think it was triggered by putting the phone on silent with vibrate, and after going back to sound enabled, the notification sound problem would appear. It's been a long time, though, so I may be mixing this one up with another issue.
    07-21-2016 06:38 AM
  1. Replies: 5
    Last Post: 09-22-2016, 11:43 PM
  2. Replies: 3
    Last Post: 07-17-2016, 09:41 PM
  3. Gmail Notification
    By dmateo in forum Samsung Galaxy S7 edge
    Last Post: 07-14-2016, 05:13 PM
  4. No text message notification or sound
    Last Post: 07-12-2016, 08:08 PM
  5. Replies: 1
    Last Post: 07-12-2016, 06:48 PM
