1. PlaybookFanatic's Avatar
    Simply put. I just lost 72 percent in less than 3 hours. This has been happening for a month or so now. That, and of I'm not on wifi, you can forget great Internet connectivity. Grrrr...
    bassplayrguy likes this.
    07-15-2016 01:35 PM
  2. pkcable's Avatar
    07-15-2016 02:17 PM
  3. Gary02468's Avatar
    If a phone is working properly, it is not necessary to jump through hoops and disable half the phone's features in order to prevent extreme battery drain.
    There is some specific hardware or software flaw causing OP's problem.
    07-16-2016 07:14 AM
  4. bassplayrguy's Avatar
    Bad signal will kill batteries quickly.
    pkcable likes this.
    07-16-2016 07:45 AM
  1. how do i fix my boost lg g stylo from soft brick
    By Yadarrel Charles in forum More LG Phones
    Last Post: 07-16-2016, 06:49 PM
  2. Desperate to play but got i pod - HELP
    By nimbleneil in forum Pokemon Go
    Last Post: 07-16-2016, 01:48 PM
  3. Help? My Samsung Gear S2 is "almost" right
    By frinkles in forum Samsung Gear S2
    Last Post: 07-15-2016, 09:38 PM
  4. Why did my music player disappear?
    Last Post: 07-15-2016, 04:52 PM
  5. Why did my GPS, WiFi and Bluetooth stop working?
    By AC Question in forum Huawei P8 lite
    Last Post: 07-15-2016, 04:51 PM
