I know this may seem like another repeated thread but I am truly stuck as I have tried EVERYTHING to resolve thelse problems since the latest update. I will be as detailed as possible.
These problems only started AFTER the 6.0.1 update on the 13/07/16
Initially my Note 5 was not connecting to the chargers at all. I have 2 (legit) Samsung fast chargers and a S3 Samsung charger. So I took it to repair technicians of where I bought the phone and they told me just to take the case off (which is weird because it worked but it has never had any problem charging with the case on prior) but it worked none the less...that's until I got home.
When I first tried to charge the phone it kept connecting and disconnecting rapidly. Fast charging is also not working. Here is what I tried to fix this:
*Used other Samsung cords and charger blocks
*Disabled S Gear
*Cleaned ports
* Factory resetting phone
Nothing worked.
Then when I tried to connect to my phone to the PC tp recover some music...it would say it is charging but no Media transfer is available.
*No drop down option for Media transfer
*drivers are all up to date
* developer mode did not work
I'm getting so frustrated since this new update, I was wondering if there is anyone that can help..
Tldr; Phone rapidly connects and disconnects, charging is slow and is not connecting to PC
*Disabled S Gear
*Cleaned ports
Nothing worked.
