Anybody else having issues with Bluetooth since the update. Mine will turn off and on randomly, very annoying while on a call.
That was a good idea, but unfortunately my power saving mode is turned off already. Thanks thoughIn order for the Bluetooth to work correctly a lot of times you have to have power saving turned off. At least that's what I found.
Well I hope you find another solution and good luck!That was a good idea, but unfortunately my power saving mode is turned off already. Thanks though
