1. leodgr81's Avatar
    Ever since I did the Last Verizon Update N920VVRS2BPF4 on 7/14 on my Note 5 instead of seeing the name of the WiFi I am connected to I see Android System Contents Hidden. It also happens when I am in USB mode connected to my PC. Any one else see this happen, and how can I change it.
    07-21-2016 10:15 AM
  2. Trees's Avatar
    Where do you see the unexpected name? In Settings/WiFi? Or in the Notification bar's WiFi symbol text?
    I have a Verizon Note 5 with the same update, and am not seeing the unexpected name.
    07-22-2016 06:00 AM
  3. ratsttam's Avatar
    If you're referring to the notification shade, or even the lock screen notifications, hold down on the notification until it "pops", then hit the (i) on the right hand side.
    There will be some settings, most likely some "hide" things are enabled, slide them to "off" and your information will come back.
    beh and felburg5 like this.
    07-23-2016 01:45 AM
  4. leodgr81's Avatar
    Here is a picture of what it looks like. This never happened before the update it would always show me the WIFI network name I was connected to and the USB did not appear like this either.
    07-23-2016 01:15 PM
  5. Kelsey Wood's Avatar
    I think it is supposed to show wifi networks available but I don't understand why it would not just say that. I get this all of the time since the new update and its frustrating because when I click on the notification on the lock screen and unlock my phone it just goes to the lock screen.
    08-02-2016 12:16 AM
  6. felburg5's Avatar
    That worked great you're a genius. Thank you.
    09-21-2016 09:05 PM
  7. felburg5's Avatar
    That works great you're a genius thank you
    09-21-2016 09:06 PM
  1. Replies: 3
    Last Post: 08-07-2016, 03:22 PM
  2. Looking for Best Android Phone Battery Life
    By Dave Scarpa in forum General News & Discussion
    Last Post: 08-02-2016, 07:29 AM
  3. Any Android smartphone with dual memory card slot's?
    Last Post: 07-24-2016, 05:38 PM
  4. How can I unbrick my Android Jelly Bean and get it out of a boot loop?
    By AC Question in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-23-2016, 01:46 AM
  5. Replies: 0
    Last Post: 07-21-2016, 08:17 AM
