1. srinathp1988's Avatar
    It's not even a year since got the note 5 but my battery seems to be misbehaving. Once it was at 15% and then after 5 or 10 minutes , phone was shutdown and battery was 0%. Today the battery was charged to 100%. After i unplugged, in 5 minutes it came down to 96. I also see some random problems when battery is low (<15 ). Does this mean there is a problem with my battery and more importantly, can it be replaced( not by me) if needed?
    08-06-2016 06:57 AM
  2. Trees's Avatar
    An app like GSam Battery Monitor can help provide more information. If you have apps running that consume system resources, its feasible that battery can drop after removing phone from charger.
    08-06-2016 07:49 AM
  3. Kelly Kearns's Avatar
    Have you noticed your phone feeling really warm and/or problems with fast charging not working?
    08-06-2016 02:57 PM
  4. srinathp1988's Avatar
    Just after i unplugged when it was fully charged
    08-06-2016 04:27 PM
  5. srinathp1988's Avatar
    I have been feeling it warm since i bought it..but temperature has been around 105F and from discussions, i found it is normal..had 1 weird experience last week
    When i connected my fast charger, charging was turning on on off every second like some malfunction.phone was blinking every second. It is working fine now though
    08-06-2016 04:30 PM
  6. Kelly Kearns's Avatar
    That is high to me. My N5 has always been the coolest phone I've ever had, even feels cold to the touch. In June it started getting warm and I started having battery issues. Sent it in the motherboard had to be replaced. Got it back and sent it back again and I think it is the same issue, it was getting hot again.
    Now sometimes it got warm charging, but using, it was always super cool.
    Mine was also dropping 3-6% within 5 mins of unplugging it.
    Laura Knotek likes this.
    08-06-2016 05:57 PM
  7. srinathp1988's Avatar
    Where did you send it to? I am wondering if the fast charger i have is killing the battery. My phone was at 15% (it was fine the whole day but suddenly it was discharging pretty fast) and i connected the fast charger, the battery started going down from 15 and went to 0 in seconds..
    08-06-2016 11:05 PM
  8. srinathp1988's Avatar
    Post deleted
    08-06-2016 11:05 PM
  9. srinathp1988's Avatar
    This is the screenshot where it became 0 from 15 after i plugged inBattery problems-8102.jpg
    08-06-2016 11:07 PM
  10. Kelly Kearns's Avatar
    I sent it to Samsung.
    08-06-2016 11:53 PM
  11. Kelly Kearns's Avatar
    This is the screenshot where it became 0 from 15 after i plugged inClick image for larger version.
    Can you tap on the screen option and get the time the display was on?
    Also you might want to install GSam like was suggested.
    08-06-2016 11:56 PM
  12. Trees's Avatar
    Kelly is getting to the same thing in the post above. I see that Screen is 68% out of the battery % used since off charger. What is the brightness level? I leave mine on "Auto brightness".
    08-07-2016 07:22 AM
  13. Silentia's Avatar
    Disable 4G/LTE with new firmware, even you use wifi only, just turn off 4G, use 3G connection.
    Battery become normal again.
    08-08-2016 01:07 AM
  14. Kelly Kearns's Avatar
    That isn't normal battery though if you have to turn off 4G.
    We can try and help you run this down, there is no guarantee, but we need specific info from you.
    08-08-2016 09:51 AM
  15. srinathp1988's Avatar
    I have gsam battery already and max screen time i get is 4 hours if i am fully in wifi and dont make any calls. If i make calls and use lte, i get 2.5 to 3 hours max.
    I stopped using the fast charger for a week and so far have not seen any drastic drops in battery. So i am guessing it might be something with the adaptor and I am not going to use it anymore
    08-14-2016 09:02 PM
  16. NexusGirlX's Avatar
    The battery life on my Note 5 has always been bad if I used the stock OS. Once I rooted the phone and loaded a custom ROM onto it, my battery life has been outstanding. I bought my Note 5 in December. Here is a screenshot of my latest battery stats. I haven't used the phone much because I also have two S7 Edge phones and I've been using them for the most part the last two days.
    The few times I tired to go back to the stock OS, my battery would barely last me 8 hours. I even tried restoring the phone and without even loading any of my own apps and just leaving the phone alone at home where I couldn't use it, the battery would last eight hours.
    The ROM I am using has no preloaded apps. Other than that, it is stock and I am running Adaway on it to block ads.
    08-15-2016 07:11 AM
  17. Silentia's Avatar
    Just got new firmware security patch 1 august, battery drain problem solved.
    08-20-2016 11:29 PM
  1. Lg g4 ls991 update problem
    By venu g krish in forum LG G4
    Last Post: 08-06-2016, 09:42 PM
  2. problem with lock screen in s7
    Last Post: 08-06-2016, 03:26 AM
  3. Samsung A5 2016 problem SVoice Provider
    By ajmal25 in forum General Help and How To
    Last Post: 08-06-2016, 03:25 AM
  4. New battery and a dead phone...
    By highvoltage8 in forum Samsung Galaxy S5
    Last Post: 08-06-2016, 02:14 AM
  5. Strange listing on battery usage page
    By sctiger in forum Samsung Galaxy S6
    Last Post: 08-05-2016, 09:18 PM
