When I charge my phone it seems to go in and out of charging. it charges for a bit then doesn't, then charges again. Anyone else have this issue and what did you do to solve it? It is only 2 weeks old and does have the MM OS. Thanks
Could try a different power source to see if that is a problem. If not, then a different power adapter with the original power cord; and then a different power cord with the original adapter. Finally, a different power adapter and cord. Trying those combinations with the original power source where you are seeing the problem, and a different power source should help cover all of the possible power into the phone scenarios.
