1. Carrie Greicar's Avatar
    When I charge my phone it seems to go in and out of charging. it charges for a bit then doesn't, then charges again. Anyone else have this issue and what did you do to solve it? It is only 2 weeks old and does have the MM OS. Thanks
    08-11-2016 11:06 AM
  2. amyf27's Avatar
    So you're using the stock cord and wall adapter I assume?
    08-11-2016 03:52 PM
  3. Carrie Greicar's Avatar
    Yes I am.
    08-11-2016 05:09 PM
  4. Trees's Avatar
    Could try a different power source to see if that is a problem. If not, then a different power adapter with the original power cord; and then a different power cord with the original adapter. Finally, a different power adapter and cord. Trying those combinations with the original power source where you are seeing the problem, and a different power source should help cover all of the possible power into the phone scenarios.
    08-12-2016 05:55 AM
  1. Replies: 18
    Last Post: 08-30-2016, 07:06 AM
  2. Tab S2 9.7 Wouldn't Turn On After Charging
    By VitaminA in forum Samsung Galaxy Tab S2
    Last Post: 08-12-2016, 11:51 AM
  3. Has Anyone Ordered the Type C Charging Cable?
    By komobu in forum Samsung Galaxy Note 7
    Last Post: 08-12-2016, 09:05 AM
  4. Replies: 0
    Last Post: 08-11-2016, 11:04 AM
  5. REVELATION * * * Fixed Boot Issues * * *
    By w4phle_stomp in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-11-2016, 02:47 AM
