1. cjwaipahu's Avatar
    I have an extra S-pen and it would be nice if I could execute the air command without removing the original pen from the phone. Couldn't find a thread on this topic.
    Thx.
    08-24-2016 04:45 PM
  2. Doug Moffat's Avatar
    I'm a bit confused: assuming you have an S pen that is compatible with the Note 5 why would you have any problem using the air command feature.
    The trick is that many styli aren't compatible with the N5 including my Galaxy Pro tablet (2014) and N4 S pen.
    Plenty of compatible styli available via Amazon but beware of some outrageous prices that add nothing to the product. I got several at Best Buy that looked like normal 2 piece pens for between 15 and 20 $$. Worked great and simply attached to a suit jacket pocket. No erasure function, however.
    08-25-2016 02:03 AM
  3. cjwaipahu's Avatar
    Sorry for not being clear. The S-Pen is from an older note which seems not to be compatible.
    Would like to keep the Note 5 s-pen docked in the phone when using the other pen.. Seems like the air command only executes when I withdraw the Note 5 s-pen from the phone. I want to know if there a way around this.
    08-25-2016 02:09 AM
  4. JohnnytheK's Avatar
    Hold there s-pen close to the screen and then push the button on the s-pen. If it's compatible air command should pop up.
    08-25-2016 03:39 PM
  5. cjwaipahu's Avatar
    Did try to use the old S-Pen when the original Note 5 S Pen is docked into the phone. Click on the old s-pen but no air command. Should say the old S-Pen fully works on th Note 5 screen which includes using the clicker when I unlocked the Note 5 s-pen from the phone.
    08-26-2016 02:49 AM
  6. JohnnytheK's Avatar
    Just wondering why?
    pool_shark likes this.
    08-27-2016 03:46 PM
  7. Doug Moffat's Avatar
    I was spectacularly wrong. All my styli work included by tab pro (2014) and Note 4 PROVIDED I remove the Note 5 stylus first.
    08-27-2016 03:56 PM
  8. cjwaipahu's Avatar
    Why? Because of convenience to keep the Note 5 s-pen docked while I use the spare one. And this lessens the chance of losing the Note 5 s-pen when using the spare one and it reduces wear and tear on the entire note 5 s-pen docking system.
    08-27-2016 04:11 PM
  9. JohnnytheK's Avatar
    I'm not the word means what you think it means.😉
    08-28-2016 11:28 AM
  10. cjwaipahu's Avatar
    Oh okay. LOL! I think there's no way around it unless the phone is rooted.
    08-28-2016 02:17 PM
  11. Gbsa's Avatar
    I'm using a note 4 and I can bring up the air command with an old note 3 s pen. Here's how I did it
    Go to settings
    S pen
    Un check s pen power saver. This worked for me
    08-28-2016 02:32 PM
  12. Gbsa's Avatar
    I'm using a note 4 and I can bring up the air command with an old note 3 s pen while the note 4 pen is docked . Here's how I did it
    Go to settings
    S pen
    https://uploads.tapatalk-cdn.com/2016...50d1a12324.jpg
    08-28-2016 02:34 PM
  13. cjwaipahu's Avatar
    That's seem to be the work around as well for the Note 5! Thank you!
    Gbsa likes this.
    08-28-2016 02:42 PM
  1. Anyone else having an issue with BT in vehicles with their Note 7?
    By spasell in forum Samsung Galaxy Note 7
    Last Post: 08-25-2016, 09:04 AM
  2. Replies: 1
    Last Post: 08-24-2016, 04:29 PM
  3. Replies: 1
    Last Post: 08-24-2016, 04:23 PM
  4. Replies: 0
    Last Post: 08-24-2016, 01:59 PM
  5. How to use my dial pad during call with galaxy note 4
    Last Post: 08-24-2016, 01:57 PM
