1. nickking92's Avatar
    Hello, I had this bug since I bought a phone, every time I reboot phone with theme installed from theme store notification bar changes to Grey and black. Only solution I found is to change to default theme than re-apply another theme. This happens on absolutely every reboot. It's really annoying. Any fix?
    09-16-2016 05:37 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Have you tried uninstalling all the themes you have and then reinstalling the one you want?
    09-20-2016 08:02 AM
  3. nickking92's Avatar
    This happens only when i reboot, no matter if it is on stock theme or from the theme store, notification bar color turns grey as you see in the picture. Also i notices color changes in My files app. Might be something in system settings, my phone is rooted so maybe i can change some files and codes with root browser, i dont know
    09-20-2016 03:32 PM
  1. Verizon Note 3 Soft Bricked: System Software not Authorized by Verizon Wireless
    By captcdm501 in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 09-20-2016, 07:27 AM
  2. can i just clear my note 4 os and reload it
    Last Post: 09-16-2016, 04:19 AM
  3. Note 4 dying quicker? Dies at 40%?
    Last Post: 09-16-2016, 02:50 AM
  4. Replies: 1
    Last Post: 09-16-2016, 01:40 AM
