1. kobmays89's Avatar
    My Samsung is tanking pretty bad. I only had 2 hours of SOT and have had to charge the phone twice already. Is anyone else having this problem? How long are your phones lasting? Which features have you disabled to keep battery?
    10-13-2016 07:22 PM
  2. Ryano89's Avatar
    I'm having this problem as well. I haven't changed my usage at all, I think my battery is just degrading after over a year of use
    10-13-2016 09:13 PM
  3. kobmays89's Avatar
    I've only had my phone for 6 months. Did it start that quickly for you?
    10-14-2016 11:41 AM
  4. tadpoles's Avatar
    Have you guys all gone into applications and verified that only the things you want running are running and the things that you don't want running are disabled?
    10-14-2016 11:45 AM
  5. Ryano89's Avatar
    No it didn't, it's not awful, just definitely degraded some
    10-14-2016 11:53 AM
  6. Ryano89's Avatar
    Yes, mine isn't awful, just doesn't hold up like it used to. But I've been using this thing HARD for over a year now, so I really think it is just a battery degrading
    10-14-2016 11:54 AM
  7. tadpoles's Avatar
    Yeah, that's the thing about sealed batteries. When they degrade you have an excuse to get a new phone. For me, I like that excuse as long as my purse agrees.
    tmdublin likes this.
    10-14-2016 12:40 PM
  8. ehosey2's Avatar
    My battery on the Note5 I have has degraded to around 2400mAh. It is getting about 2 hours less than when new about 14 months ago. I am thinking of getting the battery replaced. Anybody get the battery replaced on theirs?
    10-14-2016 12:50 PM
  9. kobmays89's Avatar
    Yes I went into and verified which apps I'm running. I've basically had to disable all the features that make this an awesome phone to get through the day
    10-14-2016 01:30 PM
  10. Climb14er's Avatar
    The battery in the Note 5 or any sealed battery will definitely degrade over time. My current warranty replacement is averaging 5 to 5.5 or slightly higher SOT. My previous Note 5, after eight months of very hard use, the SOT was 3.5 and dropping.
    I can't stand sealed batteries and in the past, just popped in a fresh, new factory battery and kept the older ones as spares. I went on my way happy with a strong battery.
    I carry extended warranty as well and at some time will have to go to battle once again with Verizon to get them to send me a refurbished phone, with hopefully a fresh battery.
    Dealing with Samsung, I no longer do that! I absolutely hate their distasteful so called customer support. No wonder why the Note 7 failed! They have an ego so huge, the failed phone came back to haunt them.
    10-14-2016 05:07 PM
  11. cardboard60's Avatar
    Find and call a Batteries Plus Store.
    They will go into the phone and replace the battery.
    10-14-2016 07:17 PM
  12. Climb14er's Avatar
    That's right! I found a local very reputable cell phone repair shop that will replace Note 5 battery with factory new battery for $72.00. That's comparable to what Apple will charge for an iPhone battery replacement.
    I'm still going to push on Verizon as I'm on extended warranty. Being long term customer, they'll bend a little. But it's getting more difficult due to Samsung to get warranty battery degraded replacements. Like I said, Samsung... stinks as a company. Apple with my MacBook Pro Retina is a much better customer service company. If Sammy gives me more hassle, I'm gone!
    10-14-2016 07:57 PM
  13. PDXNW's Avatar
    I've recently been noticing the battery life on my Note 5 has been draining faster than normal. Then today I was at about 30% and my phone turned itself off. When I tried to turn it back on it gave me the 0% message telling me to plug it in. I'm probably right around having owned it for a year.
    10-15-2016 09:44 PM
  14. srinathp1988's Avatar
    I have my note 5 for a year and the max sot i have got is 4 hours and that's when I am on wifi completely and data is off. On avg i get 2.5 hrs. But the weird issue i am having recently is when battery is below 15, it reduces drastically and when i charge, immediately battery goes to from say 11 to 15 in a second
    10-23-2016 07:57 PM
  15. EdwinT's Avatar
    Did you do a factory reset and let it run for a couple days?
    10-25-2016 02:48 PM
  16. acles003's Avatar
    I've just resigned to keeping my Note 5 on battery saver mode all the time. Looking to upgrade to LG V20.
    10-25-2016 07:09 PM
  17. Solpete's Avatar
    I just bought a n9208 from a store in Hong Kong. I immediately installed Android 6.0.1. When my battery reaches 20 it drops to 15.. Then to 5 in a minute.. I hope this is just temporary. I fear I got a refurbished phone sent to me. It was in mint condition but the phone didn't have any screen protection on and the box said n9200 but the sticker on the phone n9208. Weird.
    11-04-2016 02:22 PM
  18. guacapoli's Avatar
    Its definitely the 6.0.1. It's making my battery utterly useless.
    11-09-2016 01:43 PM
  19. cardboard60's Avatar
    They say charge yer battery when it gets to 30%
    How many of you sit around a computer and could keep a cord and plug it into the USB port.
    11-09-2016 02:17 PM
  20. TheMatrix31's Avatar
    I don't know what it is but mine's been a disaster these last few weeks too.
    *shrug*
    11-10-2016 03:56 AM
  21. Solpete's Avatar
    Replying to my own post... my battery life has gone from very poor to stellar. I had almost 7 hours SOT watching the US election using HD stream at 35% brightness... battery drops less than 1 percent per hour at night! All I did was disable all bloatware with package disabler and running greenify... really happy now was convinced that my battery was bad.
    11-10-2016 09:43 AM
  1. Samsung galaxy s6 Edge battery issue
    By Andyvalver in forum Samsung Galaxy S6 edge
    Last Post: 10-17-2016, 08:14 PM
  2. Android system at 32% draining the battery!
    By dl-73 in forum Samsung Galaxy S7
    Last Post: 10-16-2016, 08:51 AM
  3. Battery Problems or not?
    By StephanHH in forum Samsung Galaxy S7
    Last Post: 10-14-2016, 07:17 AM
  4. Wild Battery indications on Droid Turbo 2
    Last Post: 10-13-2016, 12:06 PM
  5. Sept update battery solution?
    By mundo472 in forum Samsung Galaxy S7 edge
    Last Post: 10-13-2016, 08:52 AM
