1. RogueRunner's Avatar
    I'm sending my Note 7 back and getting the Note 5 (I never owned a Note before my 7) and am wondering if I can keep my finer-point S-pen from the Note 7 to fit in my note 5? I don't want to stick it in there and get it stuck or something. Anyone tried that?
    Thanks
    John
    10-26-2016 12:00 PM
  2. Jude526's Avatar
    No. The Note5 will have its own.
    10-26-2016 12:20 PM
  3. brau0303's Avatar
    I am told that the N7 s-pen will fit but it's a bit shorter and slightly thinner, I would keep the N7 s-pen as a memento but not use it in the N5. (due to N7 version being shorter/thinner, you would likely have it get stuck or have it fall out)
    Cheers,
    BR
    RIP N7
    10-26-2016 01:48 PM
  4. RogueRunner's Avatar
    So - as I understand it - the tips are replaceable... wonder if I can put the thinner note 7 tip in the note 5 s-pen. That's probably not as risky of a test as putting in the 7 s-pen into the phone.
    10-26-2016 01:48 PM
  5. Jay G63's Avatar
    Don't remember which thread i read it in but other people were doing this and loved it with the 7 tip.
    10-26-2016 06:14 PM
  6. blackhemi4x4's Avatar
    The pen will go in the hole but doesn't stay in.
    RogueRunner likes this.
    10-26-2016 06:19 PM
  7. treedabl's Avatar
    I just got the Note 5 today as a replacement for my Note 7. Changed out the tip and it works great. Sad to be saying goodbye to my Note 7.
    10-26-2016 06:26 PM
  8. badgerfrisch's Avatar
    Does the Note 7s finer tip work any better than the traditional Note 5 S Pen top?
    10-26-2016 09:50 PM
  9. treedabl's Avatar
    I like it. Maybe because I'm used to the tip from the Note 7 now. I have both tips so I can switch back and forth to see the difference. I'll check back and let you know after a couple of days.
    10-26-2016 10:22 PM
  10. Jude526's Avatar
    Don't think k it's right to keep the Spen when you have to return the phone. You might very well get charged for it
    10-26-2016 10:47 PM
  11. treedabl's Avatar
    What are you talking about? I'm referring to the tips, not the pen. But, if you watch the video of how to send back the Note 7 device, they don't want any of the accessories, just the phone. They plan to destroy them. But, if all I get from this debacle is a useless SPen then I wouldn't feel bad at all.
    10-26-2016 10:57 PM
  12. blackhemi4x4's Avatar
    I kept my spen, chargers, USB cables, spen tips, and headphones one all 3 of my note 7's. They don't want those back, it's just more stuff they would have to dispose. All they needed back was the phone itself.
    It was a recalled phone. Not a buyer's remorse purchase. Nothing wrong at all for keeping the goodies.
    10-27-2016 12:32 AM
  13. ehosey2's Avatar
    I kept the bag of S-Pen tips from my Note7 and use one on my Note5. They work great.
    10-27-2016 05:42 AM
  14. RogueRunner's Avatar
    Awesome...good to know.
    10-27-2016 03:32 PM
  1. Anyone used both Note 5 and S7 Edge
    By amyf27 in forum Samsung Galaxy S7 edge
    Last Post: 10-29-2016, 08:02 PM
  2. Replies: 2
    Last Post: 10-27-2016, 12:56 AM
  3. got my replacement Note 5, but..
    By ScottRx82 in forum Samsung Galaxy Note 7
    Last Post: 10-26-2016, 11:03 PM
  4. Replies: 2
    Last Post: 10-26-2016, 11:41 AM
  5. Texts being delivered in stock messaging app
    Last Post: 10-26-2016, 11:06 AM
