1. Geo_Nexus's Avatar
    Everything seemed normal with the phone today, no problems or anything. It was sitting on the table for a while this evening and she went to use it and it wouldn't wake up. She tried turning it on to see if it got shut off and still nothing. It doesn't seem to be charging either as nothing happens when it's plugged in. Any ideas as to what's going on and how to fix it? Already tried pressing and holding power, volume down, and home which didn't work.
    11-19-2016 10:39 PM
  2. Jude526's Avatar
    It could be the battery itself. But I would first check out the charging port. Might have dust built up inside. Take a can of compressed air to it and see if that helps. It could be the charger is bad. You want to use authentic Samsung USB and not 3rd party.
    If it is the battery it can b end replaced by a computer guy or send to Samsung directly.
    If your mom has insurance she could pay the deductible and get a replacement.
    Hope it's minor.
    11-20-2016 12:35 AM
  3. JohnnytheK's Avatar
    More likely it's the charging cable, they are made very cheaply and the wires are hair thin.
    11-21-2016 08:20 AM
  4. Jude526's Avatar
    Check out everything suggested. I sold wireless for 5 yrs. Could be the charger. The charging port or the battery
    11-21-2016 09:09 PM
  1. Replies: 1
    Last Post: 11-20-2016, 02:04 PM
  2. Why are my texted mms images coming up broken?
    Last Post: 11-20-2016, 07:56 AM
  3. How do I get the edge side screen to stay on?
    By HatchNRA in forum Samsung Galaxy S7 edge
    Last Post: 11-20-2016, 06:21 AM
  4. Replies: 1
    Last Post: 11-19-2016, 10:45 PM
  5. videos disappeared after one viewing on galaxy s7 edge
    Last Post: 11-19-2016, 09:55 PM
