1. mwake4goten's Avatar
    Can anyone signpost me to certified reliable car adapters charging units for the note 5...seen some on Amazon but a bit bamboozled by all the different offers...just worried by the fake ones that might damage my phone... Many thanks
    11-28-2016 11:45 AM
  2. Climb14er's Avatar
    I've used the Anker quick speed car and home chargers for my Note 5 and they have been totally reliable, no problems at all. Add on their cables and I do not concern myself when I charge the Note 5.
    mwake4goten likes this.
    11-28-2016 12:24 PM
  3. Brad Bilger's Avatar
    I just use one I got years ago from Wal-Mart. Standard usb, two outlet. One outlet for my phone, the other for my GoPro. Never had a bit of problem with either one. I like the insignia cables from best buy because I like the thicker heavier cables that are longer.
    11-28-2016 02:44 PM
  4. Super Dave426's Avatar
    I use an Anker Quick Charge 2.0 dual port in 1 car and an Aukey Quick Charge in another, no problem at all and fully charged quickly.
    11-29-2016 02:40 PM
  5. 420lyfe's Avatar
    I use bullet adapter and regular usb cable. Whole set cost me $2 free shipping on ebay, been using it for over a year on my note5 and no issues... I don't believe in paying $20-30 for a car charger...
    11-29-2016 02:45 PM
  6. Soylent_Green's Avatar
    I use an Aukey QuickCharge that I got for $4 on Amazon, works great.
    11-29-2016 10:25 PM
  7. mwake4goten's Avatar
    Excellent thank you for replies...The reason I was a bit anxious about fake chargers is because I also just bought the HTC 10 and there is a big crap show about making sure you have the right charger, even non fake ones as there is an issue with the way HTC implemented the quick charge technology in thr 10. Basically a incompatible charger or even cable can damage the phone. Crazy...I guess the note 5 doesn't have that issue as much, thank God!
    11-30-2016 11:05 AM
  8. guacapoli's Avatar
    11-30-2016 03:47 PM
  9. Soylent_Green's Avatar
    Aukey or Anker are solid brands, or go boring and spend more for a Samsung branded one.
    11-30-2016 04:45 PM
  10. Jude526's Avatar
    I purchased from my carrier. I won't use 3rd party. My phone is expensive. Only using recommended charger
    12-01-2016 09:18 PM
  1. Replies: 43
    Last Post: 12-03-2016, 03:34 PM
  2. 7.1.1 for Pixel/Pixel XL
    By Almeuit in forum Google Pixel & Pixel XL
    Last Post: 11-30-2016, 06:24 AM
  3. How to factory reset for a new user?
    Last Post: 11-28-2016, 11:44 AM
