1. Brew61's Avatar
    I have a Galaxy Note 5 and I use a Jabra freeway bluetooth in my car. When I try and make a call it says it can not find a network connection. Now I use to have a Samsung S4 and when I push the button on the bluetooth to make a call I would say "Phone Commands" then it would ask me what I wanted to do and I would say "call so and so" and it would call them. I would have no wifi and data would be turned off.
    Now with the Note 5 I push the button and then say "phone commands" it comes back and says can not find network connection. If I have wifi or my data turned on it will work. So why can I not make a call if I have no wifi or data service?
    Bruce McMillan
    Samsung Note 5 with Virgin Canada
    01-06-2017 01:52 PM
  2. amyf27's Avatar
    Hmm. I have a Bluetooth stereo and I've just started the call on the phone (dialed) before going on the car and it rings through the Bluetooth speakers and I can talk hands free. I'll have to see about the calling feature. It should work if you setup "ok google" where Google voice assistant helps you make the call out
    01-06-2017 02:03 PM
  3. underway99's Avatar
    I think the Google assistant and/or Samsung S-Voice requires a data connection to perform some functions. Also check to see if you have WiFi calling or HD calling enabled. If so, disable them and try again.
    amyf27 likes this.
    01-06-2017 06:18 PM
  4. Brew61's Avatar
    Ok I have looked all through my phone but can not find Wifi or HD calling setting. Where is it?
    Thanks
    Bruce
    01-07-2017 02:05 PM
  5. underway99's Avatar
    Look at SETTINGS, then find ADVANCED CALLING. The name may be different depending on your carrier but, whatever it's called, it will likely be in the WIRELESS AND NETWORKS section at the top of SETTINGS. I've seen various reports that the advanced calling features sometimes cause interference with BT connections.
    It doesn't sound like that's your issue though. I missed the part of your OP where you said that your BT commands work when you have a network connection. You don't say if you can make calls by voice without the BT.
    The S4 is three going on four years old. A lot of the functions that used to be executed entirely on the phone are now run from or through the cloud. You're apparently asking the newer Note 5 to do something that requires data access. You should be able to dial directly from the phone, or call from your contact list.
    01-07-2017 02:37 PM
  6. Brew61's Avatar
    Ok still could not find Wifi or HD call. Did a search for it and it never came up. But I think I fixed the problem. When I first connected with my blue tooth and asked to use either S Voice or Google app to use as default, I guess I picked S Voice, I have now cleared that and picked Google app. I turned off wifi and data and was able to make a call by using voice commands into my bluetooth.
    Bruce
    01-07-2017 04:20 PM
  7. underway99's Avatar
    Good to hear that you found the culprit. I've not used voice commands in a very long time.
    01-07-2017 05:11 PM
  1. Replies: 1
    Last Post: 01-06-2017, 02:01 PM
  2. Samsung Note 5 Bluetooth calls
    Last Post: 01-06-2017, 01:39 PM
  3. How to call forward on an M7
    By Dalcron in forum HTC One M7
    Last Post: 01-06-2017, 12:25 PM
  4. Android bluetooth version in general
    Last Post: 01-06-2017, 08:00 AM
  5. Replies: 0
    Last Post: 01-06-2017, 02:20 AM
