1. texn884's Avatar
    Hi all,
    One thing I miss from my BlackBerry Priv is the Double Tap on the screen to wake the screen.
    Does the Note 5 have a setting to be able to do this in MM OS? I get tired of pressing the button at the bottom all the time.
    Any suggestions?
    Thanks
    01-16-2017 06:25 PM
  2. ratsttam's Avatar
    Not that I'm aware of...
    And as far as I know, an app to replicate this functionality would just cause wakelocks basically killing your battery life.
    01-16-2017 06:50 PM
  3. texn884's Avatar
    hmmmmm
    01-16-2017 06:51 PM
  4. prolongExistence's Avatar
    Hi all,
    Any suggestions?
    Thanks
    Until I just read this post I thought that was a feature exclusive to LG. Guess I just learned something. My household has gone through several different Samsung devices including the Note 5 and none of them have had that feature.
    01-17-2017 12:05 AM
  5. Stylazation's Avatar
    It doesn't support it out of the box but it is very capable of that.
    01-17-2017 12:52 AM
  6. texn884's Avatar
    the only thing I found is you can set it to use the sensor to wave your hand over it and it will wake the screen.
    I wonder why the heck it does not since the Priv can do it i guess BB has always had some nice features that others dont!
    01-17-2017 08:04 AM
  7. srgonu's Avatar
    Even OP3 and nexus 5x supports it natively. On Note 5 you can install nova launcher and enable that gesture.
    01-17-2017 10:20 AM
  8. vm81's Avatar
    Nova can lock your screen with double tap, not the other way around...It can't wake screen.
    Also, fingerprint won't work for unlocking if you enable double tap to lock screen...That's why I stopped using it.
    01-17-2017 05:29 PM
  9. texn884's Avatar
    Well crap I guess BlackBerry was far superior in a few ways verses Android
    01-17-2017 05:37 PM
  10. Super Dave426's Avatar
    I wouldn't say that my HTC One M8 had the double tap wake 3 years ago.
    01-17-2017 05:55 PM
  11. prolongExistence's Avatar
    Maybe it's just me but I don't get it. How is double tapping on the screen any easier/better than tapping the Home button that is just a couple mm below the screen?
    bassplayrguy likes this.
    01-18-2017 01:12 AM
  12. Super Dave426's Avatar
    I found it to be a negative, if I put my phone in my shirt pocket with the screen facing my chest, for protection, it could turn on and each chest tap started to select apps from the screen. I like the home button my screen doesn't accidentally turn on.
    01-18-2017 03:24 PM
  13. kway_NY's Avatar
    I have used Gravity Screen on my notes 4,5,7.& 5 gain. I love it. Hardly ever use the bottom button. Close my case cover or put in my pocket it goes off. Pull it out, it turns on and swipe or use finger print. It's like waving your hand over the sensor. You can set up so if you lay it down it goes off, pick it up and on. It takes some experimenting to get it the way you want, but when you do, it's great.
    01-18-2017 09:08 PM
  14. texn884's Avatar
    Well it does not just turn the screen on you double tap the screen and there you go your in action.
    I get tired if pressing the button. I guess you Never have had a BlackBerry and enjoyed that feature and yes it was on the Priv running MM
    The OS has a setting to use the wave your hand over the sensor and it will wake but using your finger to tap is so fricking sweet and easy
    01-19-2017 05:32 PM
  15. texn884's Avatar
    I just loaded this app and its pretty cool this might be what i was looking for, thanks
    01-19-2017 05:48 PM
  16. kway_NY's Avatar
    You are Welcome, the settings take some trials, but once you get them the way you like them, it's great.
    01-19-2017 06:21 PM
  17. texn884's Avatar
    I am liking it
    01-19-2017 08:01 PM
  18. myandroidgs6's Avatar
    Is it this one you 're using ?
    01-20-2017 01:07 PM
  19. texn884's Avatar
    Yes
    This app sucks
    01-22-2017 04:07 PM
  20. Lefty724's Avatar
    I was looking in my Nova setting for the Note 5 and couldn't find anything for double tap to wake.
    After a little searching, I was able to find this app and it seems to work pretty good? Give it a shot and see what you think?
    https://play.google.com/store/apps/d...amworks.knockz
    01-31-2017 08:27 PM
  21. vm81's Avatar
    This app does not lock or turn off your screen...It just displays black color on screen so you don't see anything...Will kill battery.
    Lefty724 likes this.
    01-31-2017 08:46 PM
  22. Lefty724's Avatar
    Thanks for that.
    It seems to wake the screen from Locked with a double tap and also seems to lock the screen even though the bottom buttons stay lit for about 5-10 seconds. It's definitely locking the screen though?
    I'll play with it a little more and report back.
    01-31-2017 08:56 PM
  1. Sms lost want to text but can't
    Last Post: 01-17-2017, 05:42 PM
  2. Replies: 0
    Last Post: 01-16-2017, 05:39 PM
  3. Replies: 0
    Last Post: 01-16-2017, 05:24 PM
  4. Replies: 1
    Last Post: 01-16-2017, 05:17 PM
  5. Replies: 0
    Last Post: 01-16-2017, 05:02 PM
