1. dougdraws's Avatar
    I have a Note 5 with AT&T. I've had the phone now for about five months and haven't had any issues with it, but this morning when I got up I found the phone was dead. I know when I went to bed it had about 60% juice so I was kind of surprised. Had to plug the charger in and then I wiped the cache partition and rebooted. I have the latest version of Marshmallow (6.0.1) and a couple days ago it said it had another system update.
    I may try a tip I found while researching this odd issue; someone said to boot into safe mode before going to bed and see what happens in the morning. May be an app or something that caused the battery drain.
    Here's a pic of my Battery screen. You can see the big spike drop to 0 (this was before I put it on the charger).
    Anyone else experience this sudden bizarre battery drain just overnight?
    01-23-2017 12:26 PM
  2. amyf27's Avatar
    When you go to bed, do you turn off wifi, Internet, and auto sync, also lower acreen brightness? Might be good idea to even put into battery save mode.
    01-23-2017 01:00 PM
  3. dougdraws's Avatar
    Sorry, forgot to mention that. When I go to bed I turn on Airplane mode.
    01-23-2017 02:57 PM
  4. BarfingMonkey's Avatar
    Did you add or change anything in your phone recently. Cause 9 times out of 10, it was something that was changed. Think hard, it may have been something real simple.
    01-23-2017 09:08 PM
  5. dougdraws's Avatar
    It had to be something, because it hasn't happened again. I just don't know what it was. Or perhaps it's just old age memory and the battery was low when I went to bed, lol.
    BarfingMonkey likes this.
    01-27-2017 11:36 AM
  1. Battery not charging
    By Moto0685 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-06-2017, 02:48 PM
  2. Battery?
    By cgentil in forum Samsung Galaxy S4
    Last Post: 01-25-2017, 09:09 PM
  3. Terrible Battery Life and Texts Unable to Send
    By Turns31 in forum Samsung Galaxy S6
    Last Post: 01-24-2017, 10:36 AM
  4. Samsung Note 4 won't boot. [SOLVED]
    By Overdrive458 in forum Samsung Galaxy Note 4
    Last Post: 01-24-2017, 04:24 AM
  5. Display Note 5 on TV, broken screen
    Last Post: 01-23-2017, 09:37 AM
