1. AC Question's Avatar
    is there a reliable place to buy note 5 oem battery replacement? im not sure ebay and amazon is the best. any suggestion? if u know good seller from ebay or amazon, that works too. im just not sure which one is trustworthy
    02-18-2017 12:25 AM
  2. underway99's Avatar
    These phones aren't nearly as simple to disassemble as they used to be, with all the sealed casings and such. If the Note 5 is anything like the S6 and S7, it'll be a heat gun and lots of adhesive. Even if you could find a good battery, it'd be tough to do the work yourself.
    I know it will cost a bunch, but I'd look at contacting Samsung to schedule the replacement. A bonus is that you'd also have a warranty on the battery and the work. If you have insurance on your phone, you may be able to get a replacement device as well.
    02-18-2017 04:12 PM
  3. myandroidgs6's Avatar
    Try this site , very decent ..:
    Battery for Samsung Galaxy Note 5 - Witrigs.com
    02-18-2017 07:36 PM
  1. Why is Android OS all of a sudden using 41% of my battery?
    Last Post: 03-08-2017, 01:41 PM
  2. Note 4 sd card issues
    By armin80 in forum Samsung Galaxy Note 4
    Last Post: 03-05-2017, 10:02 AM
  3. Galaxy s7 battery draining out of nowhere
    Last Post: 02-17-2017, 10:16 PM
  4. What I like about Note 4
    By datum9 in forum Samsung Galaxy Note 4
    Last Post: 02-17-2017, 10:07 PM
  5. Note 5 and Gear VR, not impressed
    By anderdea in forum Samsung Galaxy Note 5
    Last Post: 02-17-2017, 09:32 PM
