1. amyf27's Avatar
    I set out on a ride on my hulybrid bike this morning. Phone was at 45% I turned off the data and WiFi but have location on and a sports app Endomondo running to record my distance. 1.5 hrs later it was down to 10%, then at home dropped to 3 % quickly and shut off. I plugged it into my Samsung fast charge portable charger and instantly it was showing 27%. Wondering if this means my battery is starting to go? It seems fine during normal daytime with data on and auto sync. It seems when I run that endomondo app on the phone it'll drop quicker, but the odd thing was 3%, died, plugged into fast charger and instantly 25%.
    03-19-2017 12:09 PM
  2. B. Diddy's Avatar
    You're right, that could be a sign of a deteriorating battery. Under normal use, when it's down to single digits, does it always jump up to 25% as soon as you plug it in? Or is it only in this situation?
    03-19-2017 12:12 PM
  3. amyf27's Avatar
    I've never seen any of my phones do that. Well the note 4 did and when I replaced it's battery that was resolved.
    03-19-2017 12:17 PM
  4. jordans0nly's Avatar
    Could be a rouge app too. Safe mode is always a good route to go. If not doing the same things in safe mode, then it'd a bad app. If it's doing the same things in safe mode, then it's a hardware issue.
    03-19-2017 12:33 PM
  5. Dngrsone's Avatar
    Also, try powering of the phone, plug it in, then turn it on while plugged in. I find that can reset the battery charge tracking on some Galaxy devices.
    03-19-2017 12:52 PM
  1. Nexus 5x battery drain
    By AC Question in forum Nexus 5X
    Last Post: 04-05-2017, 10:58 AM
  2. grand prime plus battery drain issue
    By Kingjd123 in forum Samsung Galaxy Grand
    Last Post: 03-19-2017, 12:21 PM
  3. Samsung battery drain issue
    By Kingjd123 in forum Ask a Question
    Last Post: 03-19-2017, 11:43 AM
  4. Nexus 5x battery drain
    Last Post: 03-19-2017, 09:10 AM
  5. Replies: 1
    Last Post: 03-19-2017, 07:29 AM
