03-07-2018 08:43 PM
33 12
tools
  1. RichCMUK's Avatar
    I live in Thailand, my Note 5 received nougat on Friday 24th, since then I have had major sounds problems. Most notification sounds, s pen, undock, alarm and ringtones and others disappear. This happens daily. A restart fixes the issue.
    2 Factory resets, cleared cache , 2 resets at the Samsung customer service centre, but it happened again.
    I even replaced my S Pen, which has been sticking a little, this didn.t fix it.
    Has anyone else had this issue?
    My model number is N920c and I downloaded the official Samsung Nougat version.
    03-31-2017 10:55 AM
  2. myandroidgs6's Avatar
    I don't have Nougat yet , so can't help you much ...
    For now , can you put android marshmallow back ?
    and wait for your phone carrier to push out the update .. Safer this way .
    03-31-2017 12:06 PM
  3. RichCMUK's Avatar
    Thanks for the reply. I asked Samsung service to return it to Marshmallow, they couldn't do it. I will probably have to live with it until Samsung sends out an update. I have read of a few other people with this issue on other Samsung phones, so hopefully Samsung is aware of it and they are preparing a patch.
    03-31-2017 01:13 PM
  4. RichCMUK's Avatar
    This was an official Nougat version from Samsung using OTA,
    03-31-2017 01:14 PM
  5. TrevT's Avatar
    Hi
    Im in the UK, and after updating to Nougat, I am now having the disappearing sound issue almost daily, as you say, a reset sorts it out, anyone with any ideas how to fix it would be much appreciated
    Trev
    04-04-2017 04:03 PM
  6. RichCMUK's Avatar
    Hi Trev,
    Thank you for your reply. I'm sorry you are experiencing the same problem, but it is also good to know, I am not the only one. As for a solution, I wish there was one. I have found just a few other cases from other Samsung phones, but no info on a fix.
    I think we have no choice but to wait for Samsung to send an update, which I hope will be very soon. If you hear of any fixes, please let me know.
    Thanks
    P.S. Did you get the official Over the Air update from Samsung?
    04-05-2017 10:26 AM
  7. TrevT's Avatar
    Hi
    Update was a genuine OTA from Samsung,
    I don't suppose it matters, but just for your info, I bought he phone in Dubai and its showing as UAE in about device menu
    lets hope we get it sorted sooner rather than later
    Trev
    04-05-2017 03:39 PM
  8. TrevT's Avatar
    Hi
    I am still having this problem on a daily basis,
    I am now going to run in "safe mode" for a few days to see if this cures it
    Trev
    04-24-2017 03:45 PM
  9. underway99's Avatar
    Safe mode is a great idea in this case. You'll be able to see if the notifications work with just what came on the device, using the factory default settings. This will help you identify app or setting conflicts. If it all works as intended, then it's just a matter of identifying the offending app.
    If this doesn't isolate your issue, consider the possibility that the update file that you downloaded may have been corrupted. This is possible if your phone doesn't maintain a good and constant contact with the network while downloading the update. If that happened, the FDR would make no difference because you wouldn't be replacing the OS itself.
    The fix could be to reload the update. I would have expected the Samsung folks to do this. Download and install Samsung's Smart Switch for your PC. Here's a YouTube video that explains how to use Smart Switch. It's not my video. This for a Galaxy S6 Edge, but the process is the same. The Smart Switch application has been updated (this video is almost two years old), so it looks a little bit different than in the video. The part that you need is almost the same. In the video, the tab you want is labelled "Software Update and Initialization". Now it's called DEVICE INITIALIZATION.
    1. Connect your phone and hit the MORE button on the upper right corner of the Smart Switch window.
    2. Click on EMERGENCY SOFTWARE RECOVERY AND INITIALIZATION.
    3. Click on DEVICE INITIALIZATION.
    4. Click OK and follow the prompts.
    The software will grab the latest OS for your phone, put the phone into the correct maintenance mode, and install the OS with the latest update. This should leave your phone as though you took it from the box with Nougat preinstalled.
    TrevT likes this.
    04-24-2017 08:53 PM
  10. TrevT's Avatar
    Hi underway99
    That is a really informative reply and a very good idea,
    I think I will go straight to your suggestion and reinstall the original software, I was D/L Nougat at work with a poor signal so you could be right, plus a new install should also help to clear out any junk that has accumulated over the past few months, I will then run stock with no programs installed for a few days and see how it goes,
    please note it seems to be a problem for many makes and not just the Note 5, a look round the net throws up a few different makes all exhibiting the same problem, and lets be honest a phone that does not ring is not that useful
    many thanks again and I will report back in a few days
    Trev
    04-25-2017 02:26 AM
  11. havinhphu188's Avatar
    I have the same problem with you, my model is N920C either
    04-30-2017 07:06 PM
  12. ysstog's Avatar
    I am also having this problem. Lots of audio issues. Did a full reset and it did not help. Ugh.
    05-05-2017 10:17 AM
  13. havinhphu188's Avatar
    also, when the problem come up, I can't play music by another music player app. It toast error message: "sorry, the player does not support this type of audio file"
    05-12-2017 10:00 AM
  14. RichCMUK's Avatar
    Hi Undereay99,
    Thank you for you great advice, I have tried almost all of the things you suggested, except the reinstall from Smart switch, I will give it a try.
    I have now done a total of 7 FDR, hard, soft and at Samsung, also I tried one with just the installed apps, it still happened. I think the issue is as Trev mentioned, with the OS. The latest April security patch didn't help either.
    Thanks
    P.S. I will let all of you know if it works.
    05-15-2017 10:59 AM
  15. David Zhang4's Avatar
    I have the same problem with my note5 . I'm in Canada at bell network. After automatic update to android 7.0 the phone stop ringing in a daily basis. I have to restart the phone to make it sound up again. I did a factory reset still the same thing.
    I problem have to go back to previous version.
    Anybody's have some solutions?
    havinhphu188 likes this.
    05-15-2017 10:02 PM
  16. RichCMUK's Avatar
    Hi everyone,
    I tried the reset Underway99 recommended, using Smart Switch. Sadly, it didn't work, it has happened 3 times since the reset.
    I have now tried every possible way to reset my phone. Oh well, I guess we just have to wait for Samsung to send a patch.
    Samsung told me they can't return the phone to marshmallow.
    Any others tips will be helpful.
    05-16-2017 12:47 PM
  17. Dee Williams2's Avatar
    I'm having the same problem too. I can't assign ringtones to individuals anymore. Everyone has the same tone which I hate. I hope they fix it soon.
    05-27-2017 04:09 AM
  18. jlost's Avatar
    There was a security update recently and this fixed some issues for me. GPS is a lot fast, Google Assist actually will send a text instead of just hanging there. That's all I have noticed so far.
    05-27-2017 06:34 AM
  19. underway99's Avatar
    I'm sorry that the software reload wasn't the answer. Normally, a software issue will be fixed by reloading the OS. That presumes that the software itself is good.
    Since it doesn't appear to be widespread through all these devices, I wonder if a faulty component in the circuitry that handles the audio notifications could be the culprit? If that's the case, might we see more of this as these devices age?
    05-27-2017 08:45 AM
  20. havinhphu188's Avatar
    Hi everyone, I have a solution that needs you guy to help me test it, to make sure it work. My tip is
    Step 1. turn off the sound of s-pen (the sound that plays when you draw the s-pen or put it back).
    Step 2. Restart your phone (hold screen off button for 3 second)
    It has been a week since my last restart. I think at least it will help to extend the non-error period. Please let me know if it works or not at havinhphu188@gmail.com, for gathering data purpose
    06-02-2017 10:37 AM
  21. RichCMUK's Avatar
    Thanks for the tip.
    What type of reset did you do?
    Was it a hard reset from the recovery screen or a soft reset (factory reset) from the settings?
    I use this S pen sound to check if the error has occurred, but I'm interested to hear that you may have found a solution. Please keep us informed.
    06-04-2017 09:19 AM
  22. havinhphu188's Avatar
    Neither of it. Just a normal restart (hold the screen off 3 second), not reset. I found out that the audio of s pen is the cause of the problem accidentially, when I havent used s pen for a couple day, and there is no err. Also, there is a new patch update recently, keep me informed if it helps
    06-04-2017 06:14 PM
  23. Nikhil Prasanth's Avatar
    I had the same problem with my note.
    In my case it was an app. Hike messenger. Try uninstalling any apps to isolate the issue.
    06-05-2017 12:49 PM
  24. RichCMUK's Avatar
    I have finally found a solution to my random sound problem, thanks to havinhphu188, thank you for the tip.
    I turned off the S pen docking sound and the vibration for good measure. It has now been 2 days without a recurrence of the problem.
    Thank you to everyone for your suggestions.
    06-08-2017 12:35 PM
  25. Nicole Gonser's Avatar
    How do you turn off the S pen sound? I can't find it.
    Thanks!
    It has been a week since my last reset. I think at least it will help to extend the non-error period. Please let me know if it works or not at havinhphu188@gmail.com, for gathering data purpose
    06-09-2017 11:23 AM
33 12
  1. Not impressed AT ALL with the S8, total fail for these reasons !!!
    By Davyo in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 12:14 AM
  2. why is my note 3 says error when downloading a video
    By samrawit legesse in forum Samsung Galaxy Note 3
    Last Post: 04-04-2017, 03:50 PM
  3. how can i factory mode my android devise with pc?
    Last Post: 03-31-2017, 04:50 PM
  4. Gear S and no sound!!!
    By AC Question in forum Samsung Gear S
    Last Post: 03-31-2017, 04:47 PM
  5. Replies: 1
    Last Post: 03-31-2017, 04:46 PM
