1. AC Question's Avatar
    My Samsung Note 5 had the most recent software update and ever since I cannot remove pop-up notofications. It is only possible to get rid of them by disabling notifications or having them on silent. I want to know when I receive a message but don't want to see it. I tried selecting "no pop-up" in Whatsapp but it's still there. Help please!
    04-11-2017 11:58 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Not sure if this will work on Nougat, but try HeadsOff.
    04-11-2017 02:15 PM
  3. Note5er07's Avatar
    Hi... am having the same prob. This might help. It helps mine tho. No pop ups... but still receiving notification sounds..Go to setting...notification...advance notification. Thts where you can choose which apps to stop them from popping up. Hope it works
    06-08-2017 08:13 PM
  1. Replies: 3
    Last Post: 04-12-2017, 03:46 PM
  2. Replies: 2
    Last Post: 04-11-2017, 02:47 PM
  3. How can I hook my phone up to my HDTV
    Last Post: 04-11-2017, 02:22 PM
  4. Data subscription change in progress
    By adityaakshay in forum Moto G (2016)
    Last Post: 04-11-2017, 02:18 PM
  5. Samsung s6 edge plus asking for UCM PIN after hard reboot
    Last Post: 04-11-2017, 12:15 PM
