1. riskybzns's Avatar
    Is there a way I can work around this issue when it tells me that burst shots are not supported in low light conditions? I'm to take some great lightning pics and it's ticking me off!!! I know this wasn't a problem when I had my note 2.
    Thanks!!
    04-16-2017 12:53 AM
  2. mhinc's Avatar
    Thanks!!
    In theory, since you are using burst mode. There is no time to focus, hence why you are getting the error you are getting in a low light situation, it's not able to focus hence it's not able to take the shot. It's possible your Note 2 didn't have the technology to for the focusing.
    04-16-2017 04:15 AM
  1. Replies: 1
    Last Post: 04-15-2017, 02:34 AM
  2. Replies: 1
  3. Replies: 0
    Last Post: 04-14-2017, 02:15 PM
  4. Replies: 0
  5. jumping for light itel 1705
    By ndunguamos in forum Ask a Question
    Last Post: 04-14-2017, 06:13 AM
