1. momof3b1g's Avatar
    I have noticed recently that my Note 5, that is only 5 months old. Is not charging completely before it stops charging. If I unplug it, and plug it back in(whether its on the phone end or the outlet end.) It will begin charging again. It seems to have started after the latest update to Nougat. Is there a fix? Is this related to the update?
    04-30-2017 09:00 PM
  2. B. Diddy's Avatar
    Have you tried a different charging cable/plug?
    04-30-2017 10:51 PM
  3. debdroid1a's Avatar
    Mine is working fine. Check the cable. I had a bad one, just like your problem, and had to replace it.
    B. Diddy likes this.
    05-01-2017 08:09 AM
  1. Replies: 8
    Last Post: 06-24-2018, 02:25 PM
  2. Samsung Stock calendar not showing entry names
    By ericf4 in forum Samsung Galaxy S8 & S8+
    Last Post: 08-02-2017, 04:38 PM
  3. Replies: 3
    Last Post: 05-01-2017, 01:32 PM
  4. Samsung pay
    By s.c.russell in forum Axon 7 & Axon 7 mini
    Last Post: 05-01-2017, 11:49 AM
  5. Have an amgoo phone will charge but will not come on
    Last Post: 04-30-2017, 10:58 PM
