1. dougdraws's Avatar
    I'm just curious what other Note 5 owners get when using the stock charger that came with their phone.
    When I first got my phone (about eight months ago) whenever I plugged the charger in it didn't seem to take very long to fully charge. I usually charge mine when it's down near 20%, and for some reason now it takes roughly 2 hours 30 minutes until fully charged.
    I'm also wondering if using a different charger may have done something to the charging process? I sometimes use one of those power bricks when I'm at work or not near an outlet.
    05-01-2017 12:45 PM
  2. Climb14er's Avatar
    I use both the Samsung charger and Anker quick charger and both from 40% remaining, get to full charge in about seventy minutes.
    Most times I just top off to 80% because the fast charging of the Note 5 is so good.
    05-01-2017 01:23 PM
  3. dougdraws's Avatar
    Something isn't right, because my phone used to charge a lot faster using the stock charger. I wonder if something happened to it, or maybe it's Nougat related.
    05-01-2017 01:39 PM
  4. 2ndHalfCor's Avatar
    I don't have any actual numbers, just my observations since I installed Nougat (T-Mobile). While it says it is quick-charging, it seems slower than the estimated times given and much slower than it used to fast charge under Marshmallow. I think the changes that came with Nougat slowed down the charging.
    05-01-2017 02:36 PM
  5. pduffer's Avatar
    I've not noticed any slowdown since the Nougat update. I normally use the Samsung wireless charger.
    05-01-2017 07:56 PM
  6. NexusGirlX's Avatar
    I usually charge mine when it gets between 5-10% and it takes about 70-80 minutes or so. I haven't upgraded to Nougat and probably won't.
    05-01-2017 08:29 PM
  7. dougdraws's Avatar
    I just tried something. I'm at 28% battery, so I plugged the power brick into the phone and it said 2 hours to fully charged. Then I plugged the stock Samsung charger into the phone and it said 4 hours and 30 minutes until fully charged.
    Definitely something going on here. Maybe the stock charger is getting bad? Think I'll head into the AT&T store and see what they say.
    05-02-2017 10:39 AM
  8. dougdraws's Avatar
    I took it to the AT&T store and she tested both the power brick and the adapter and they both read the same amount of charge time. We figured out the culprit must be this.....
    In the basement room I have there's only two outlets, and so one has a big power strip for all my computer/TV crap and then there's the one pictured here. She suggested I plug the adapter into an outlet by itself and see if that fixes the charging issue.
    05-02-2017 02:40 PM
  9. yarnsrj's Avatar
    I've noticed that with the OEM charger, when I plug my phone into it, I have to unplug it then plug it back in again for it to say quick charge. Since nougat update!
    05-03-2017 03:02 AM
  1. How to get rid of Google captcha virus on smartphone?
    By ex0LL in forum General Help and How To
    Last Post: 04-12-2018, 12:16 PM
  2. Replies: 1
    Last Post: 05-01-2017, 09:54 PM
  3. Replies: 2
    Last Post: 05-01-2017, 03:39 PM
  4. Replies: 1
    Last Post: 05-01-2017, 12:22 PM
  5. Does the microphone on Galaxy headphones work with iMac?
    Last Post: 05-01-2017, 12:16 PM
