A
AC Question
So I want to buy the note 5 and i don't want it to be fake but when i went and checked it i noticed that the buttons on the navigation bar are already visible even before touching them. Normally you can only see the home button and after you touch either side on the navigation bar the buttons will light up and be visible.I just want to make sure if that is a sign that the note 5 is fake .
