Keyboard Problems after Nougat Update.
TV417
76
Now, to write, I have to click on that keyboard icon arrow is pointing to. I never used the textwriting feature. How do i get it back to normal?
I
underway99
Trusted Member
Apr 7, 2011
597
Try resetting the keyboard to its default settings. Expect that you will likely lose your custom dictionaries and word lists. I'd back those up before I reset anything.
Find SETTINGS, then LANGUAGE AND INPUT.
Tap SAMSUNG KEYBOARD (or whatever keyboard you have set as the default)
Find and tap RESET SETTINGS.
If your keyboard doesn't have a reset function, you can also reset the keyboard settings in the application manager.
Open SETTINGS, then find APPS (or APPLICATIONS)
Scroll down the list to find and tap on your keyboard (BlackBerry, SwiftKey, Gboard, etc).
Tap FORCE STOP, then STORAGE, then CLEAR DATA.
2fedes
