1. jmj227's Avatar
    Have any of you noticed a difference in battery life when dropping screen resolution from WQHD to FHD? My battery life sucks, so I went a full day on FHD and noticed zero difference.
    Attached Thumbnails Screen Resolution and Battery Life-screenshot_20170825-201528.jpg   Screen Resolution and Battery Life-screenshot_20170825-201521.jpg
    08-25-2017 07:23 PM
  2. L0n3N1nja's Avatar
    It helps, but only while the screen is on and not that much unless your doing something graphically demanding.
    Phone idle being your biggest power draw makes me wonder if you've got poor coverage and it's working to maintain a connection to the towers. Most people don't realize poor network connection causes battery drain.
    08-25-2017 09:30 PM
  3. jmj227's Avatar
    Yeah most of the solutions to N5 battery drain have always pointed to poor coverage. However, when I travel for business and spend a week in a metro area with 5 bar signal I experience similar battery life. And putting my phone in airplane mode and using wi-fi calling does not help either. So, I'm not really sure what the deal with my N5 is. I've had it for 2 years. May need to do the upgrade to the N8.
    08-26-2017 09:09 PM
  4. JPK Omaha's Avatar
    screen brightness is my biggest battery draw. also nougat has the battery features that put all the apps to sleep. that helps too
    08-30-2017 10:05 PM
  1. How is the battery life of the op5 compared to the op3T?
    By amr ashraf mostafa in forum OnePlus 5 & 5T
    Last Post: 09-02-2017, 05:48 PM
  2. Replies: 1
    Last Post: 08-29-2017, 01:04 PM
  3. Samsung Galaxy S7 edge black screen
    Last Post: 08-25-2017, 07:57 PM
  4. Add new screen to desktop
    Last Post: 08-25-2017, 06:50 PM
  5. B1-730HD and B1-750HD motherboard
    Last Post: 08-25-2017, 06:26 PM
