1. RichCMUK's Avatar
    I bought my Note 5 a year ago. A couple of days ago, I noticed a red light flashing for a second on the back of the phone, just below the flash. It seems to happen when I am in a dark place and it happens when I press the home key to unlock the phone.
    This is probably not a problem, but I have never noticed it before. My guess is that is something to do with the flash and the camera.
    Any help, will be appreciated.
    Thanks
    09-04-2017 10:53 AM
  2. Golfdriver97's Avatar
    Not sure what that could be. I just tried on my N5, and I didn't see a red light. What carrier and build number do you have?
    09-04-2017 11:08 AM
  3. PJRed2008's Avatar
    Some cameras have a red light to help the cam set flash or focus I think. Also, aren't heart rate monitors red?
    09-04-2017 11:13 AM
  4. RichCMUK's Avatar
    I have got the "C" version.
    It is the heart rate light that is flashing, it just did it again.
    A quick press on the home key, in low light seems to activate it.
    Thanks for your replies.
    Tim1954 likes this.
    09-04-2017 11:45 AM
  5. Golfdriver97's Avatar
    Maybe a red eye reduction light?
    09-04-2017 03:02 PM
  6. Scatpackrat's Avatar
    I have a galaxy note 8. When I am using my front facing camera (selfie camera) a little red light appears when anything gets within a cm of it. I believe it is some type of sensor. Hope this helps
    01-16-2018 10:13 PM
  7. Scatpackrat's Avatar
    Probably so
    01-16-2018 10:13 PM
  8. jlost's Avatar
    its the heart rate monitor
    01-20-2018 04:31 PM
  9. Brock malone 1988's Avatar
    Its a "button" for taking selfies. If you "tap" the flash in selfie mode it takes a photo :-) (worked it out accidently)
    jlost likes this.
    01-20-2018 04:52 PM
  10. jlost's Avatar
    It's actually both lol
    01-20-2018 05:33 PM
  1. Find the Difference Halloween - Spot Differences
    By Calenislija in forum Android Games
    Last Post: 10-25-2018, 06:26 AM
  2. Replies: 6
    Last Post: 09-09-2017, 11:11 PM
  3. Replies: 2
    Last Post: 09-04-2017, 09:33 AM
  4. Replies: 0
    Last Post: 09-04-2017, 02:18 AM
