1. daves221's Avatar
    in the past week, I've experienced a sudden and massive battery drain .. my phone goes from a reported 50ish % to zero in a matter of minutes. In both cases, I've been using the stock camera. The culprit doesn't seem to show up in the list of apps using battery, as the % would be more immense than I see.
    Symptom is sluggish camera response followed by dead phone. Then I look @ the battery usage chart and it shows gradual decline then a cliff where it went from say 65% to 0% immediately.
    Any suggestions for tracking this down? I think the battery reported % is ok and it's really that soemthing killed id (vs. really having little battery left and the report being inaccurate?). My note 5 is about 2 years old so I think (??) the battery is still ok.
    10-18-2017 04:25 PM
  2. B. Diddy's Avatar
    Drain that fast is suspicious for a failing battery (like with a battery dendrite). Does it always happen, or are there other times when the battery drain is normal?
    kct1975 likes this.
    10-18-2017 05:04 PM
  3. daves221's Avatar
    mostly normal.. happened 2x in the past two weeks. phone is about 2 years old.
    Interesting thing is that Android charts the drain.
    10-19-2017 07:14 AM
  4. daves221's Avatar
    Battery drain screen shot. Note audio server which I first suspected of large battery drain 3 weeks ago as it had the highest percentage and my drain was abnormally very high (but not massively sudden). That seems to have settled but I still see audio server and not sure why as large as it still is (no media usage on my part).
    10-19-2017 07:20 AM
  5. B. Diddy's Avatar
    There might be a corrupt media file saved somewhere -- consider backing up all of your audio and video files, and then deleting them from the phone.
    That steep drop is still highly suspicious for a dendrite. You can read a little bit more here: Battery Life and How To Improve It
    10-19-2017 09:42 AM
  6. daves221's Avatar
    thanks, I suspected a corrupt media file when I saw the audio server high usage but it settled itself in 2 days, not sure how yet. I'll check your link, thanks.
    B. Diddy likes this.
    10-19-2017 12:21 PM
  7. kct1975's Avatar
    I actually had that problem with the Nexus 6 that I used to have.
    10-27-2017 07:43 PM
  8. Aedemas's Avatar
    I have this problem too, did somebody manged to find out exactly what's the cause ?
    11-01-2017 06:08 PM
  1. Why is my tablet charging slow all of a sudden
    Last Post: 12-18-2017, 02:21 AM
  2. Has Anyones Battery Life Changed Recently?
    By NotAnAppleGuy in forum Samsung Galaxy Note 8
    Last Post: 10-24-2017, 01:04 PM
  3. Battery LIfe of S8 Active vs. Other Phones
    By PowrDroid in forum Samsung Galaxy S8 Active
    Last Post: 10-19-2017, 11:59 AM
  4. Poor battery life
    Last Post: 10-18-2017, 03:47 PM
  5. Does poor mobile and wi-fi signal drain battery?
    Last Post: 10-18-2017, 03:25 PM
