1. Vaqar Khan's Avatar
    Hi
    My question might sound absurd. But can we install Note 4 LCD in Note 5? Is the Note 4 LCD compatible to be installed in Note 5? I know the display quality is a bit different but aside from that is it compatible?
    Thank u
    05-27-2018 08:24 PM
  2. hallux's Avatar
    The connectors are in different places, it won't connect.
    05-27-2018 08:49 PM
  3. Rukbat's Avatar
    Even if you rewired it, the drivers are different, and the software to run the display is different.
    05-28-2018 04:17 PM
  1. Change title of a Samsung Note on s8?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-29-2018, 10:23 AM
  2. How to change an Exchange Active sync password in android 7
    Last Post: 05-28-2018, 02:01 PM
  3. cannot change my pin in settings
    Last Post: 05-27-2018, 05:34 PM
  4. Can you put a galaxy s9 charger in the wrong way
    Last Post: 05-27-2018, 05:16 PM
  5. Change title of a Samsung Note on s8?
    Last Post: 05-27-2018, 03:40 PM
