1. d1nman's Avatar
    I've had this issue in the past- and it remedied itself for a while. Here's the deal.
    I bought my 64gb note 5 through AT&T maybe a week after release.
    I had lots of issues with it, including screen coming unglued from the frame, charging port issues, etc. Samsung kept "fixing" it under warranty, but it never really was like a new one should feel (or how mine felt when new) this was annoying because I knew how to fix the device being in phone repair for 7+ years, but with it being under warranty, why would I void it?
    So, around February (I think?) Of 2016, I went to AT&T and they gave me a new (refurbished)- but told me it would be brand new- replacement.
    This phone did fantastic. Flawless. Not an issue (other than the rear camera failing twice, replaced it twice).
    Until about 2-3 months ago.
    Now, I use my phone pretty regularly, heavily, and it has been great so I'm not just raging since the phone has had 2+ years of great usage. Best phone I've ever had, in fact. It's not even slow or anything.
    Bear with me now, because even though I know most phones inside and out, I know absolutely nothing about "flashing" Androids, reinstalling the OS, software related workings, etc. I was always on the hardware side of things. I rooted my s5 years ago but I have forgotten what I did exactly.
    OK finally to my issue- the battery life on my Note 5 is now atrocious. I have replaced the battery with a brand new one from a (as far as I know) reputable parts supplier, even ordered the better Battery offered. But my issue still persists.
    I'm getting anywhere from 30 minutes to 4 hrs off a full charge. This morning, I was watching it drop around 2% per minute, maybe more, with no apps running.
    In a mere 4 Minutes off the charger (original Samsung charger) I was from 100% to 88%
    When it gets to 30%, it will sometimes just die, or, it will begin to drop even faster if I'm really using it. 3-5% per minute.
    It's really annoying because I'm on the road alot, and need my phone. It doesn't charge well unless I use the factory charger.
    I've never "reset" or "reflashed" the phone or anything like that. I've just used it.
    I know a question will arise- what apps do you use?
    Textra
    Spotify
    Snapchat
    Instagram
    I'd say those are my top 4. I obviously have and use other apps, but not as frequently.
    I (guess) I plan on buying the note 9, but I'm just curious as to what could be causing this massive drain. I'm also open to recommendations on a new device.
    Accubattery (not sure if this is a reputable app) tells me Snapchat uses the most. I tried deleting it for a few days, but I didn't notice a difference that was like "wow! That was the issue"
    It also says my phone is using 1,300-2,500mAh at any given time, even with no apps open. Occasionally drops under 1000, for a bit, but not long
    Phone stays over 100°F most of the time, occasionally getting up to 120°F.
    Feel free to tell me what I'm doing wrong. I'm a noob when it comes to software stuff.
    Thanks everyone
    08-02-2018 11:48 AM
  2. Rukbat's Avatar
    1, Accubattery is a good app.
    2. 1,300 mA drain is excessive. You say that you were on the hardware side, I suspect some hardware causing the problem - a blown capacitor between battery and ground, perhaps. Normally I'd say a new motherboard, but disconnect the battery, then measure resistance across all the voltage rail capacitors. If you can measure to the fraction of an ohm, you might find a shorted capacitor.
    Golfdriver97 likes this.
    08-02-2018 09:10 PM
  3. anon(5719825)'s Avatar
    I have a Note 5 that has always had bad battery life since day one. I could never trace it to any one source. Several times, I even restored the phone to factory and left it sitting there with a full charge and with NO apps installed on it whatsoever and within 8 hours, the battery would be at 20-30% or so with no use at all.
    The only way that I was able to get any kind of useful life out of it was to root the phone and install a custom ROM on it that had been completely debloated. Then I could actually get 2-3 hrs screen time with maybe 12-15 hrs standby.
    Also, if your phone is shutting off when it gets to 30%, it may be the battery needs to be replaced.
    08-03-2018 04:18 AM
  4. Mike Dee's Avatar
    There is a possibility that the replacement battery is bad
    08-03-2018 05:43 AM
  5. d1nman's Avatar
    Thank you guys very much, and rukbat, that's a very good idea. I'll have to try that.
    Maybe it is this Battery, because it just dropped from 100% to 83% in 6 Minutes of standby.
    Fingers crossed.
    Battery life has never just been exceptional on here, but it's almost not even usable now.
    I thought about rooting it, but I'll probably end up getting a new phone
    08-03-2018 05:48 PM
  6. Golfdriver97's Avatar
    Fingers crossed.
    I would hold out as long as you can. Even if that means getting a cheap GSM Android to use until the next Note comes out.
    08-03-2018 07:57 PM
  7. d1nman's Avatar
    What makes you say that?
    08-03-2018 08:21 PM
  8. Golfdriver97's Avatar
    We are about a month from potential announcement of the Note. Sales might not happen until late September, making it essentially 2 months away. I was under the impression that your Note wouldn't make it that long.
    08-04-2018 08:12 AM
  1. YouTube Dark Mode for Note 8
    By ravi_us in forum Samsung Galaxy Note 8
    Last Post: 09-10-2018, 06:34 PM
  2. Note 4 What is the blue light mean when it shuts off?
    By Android Central Question in forum Samsung Galaxy Note 4
    Last Post: 08-06-2018, 04:02 PM
  3. Samsung Note 4 crashes and will not reboot??
    By Twin1965 in forum Samsung Galaxy Note 4
    Last Post: 08-06-2018, 03:59 PM
  4. Why is my battery losing charge even though it is plugged in
    Last Post: 08-02-2018, 09:22 PM
  5. My Samsung Note 3 charges to 100% but will not hold the charge.
    By Android Central Question in forum Samsung Galaxy Note 3
    Last Post: 08-02-2018, 01:22 PM
