    Hello!
    My phone is Samsung Galaxy Note 5. Whenever my phone is locked, the WiFi disconnects. I have made sure that in the Advanced WiFi setting, Keep WiFi during sleep is set to "Always." I am having a really hard time as my phone locks within 30 seconds and I always have reconnect the WiFi. All the WiFi networks are auto reconnect but they don't connect unless I turn on and off the WiFi several times.
    Can anyone suggest a solution?
    Thank you!
    11-06-2018 01:56 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Any power-saving modes turned on? Or wi-fi manager apps?
    kct1975 likes this.
    11-06-2018 11:01 AM
  3. beth9's Avatar
    Power saving mode is off. And no wi-fi manager apps.
    11-07-2018 08:12 AM
  4. B. Diddy's Avatar
    Does it also happen in Safe Mode? https://support.t-mobile.com/docs/DOC-27639
    11-07-2018 10:29 AM
  5. beth9's Avatar
    I actually reset my phone and the wi-fi is working fine now.
    Thanks!
    B. Diddy likes this.
    11-08-2018 05:19 AM
  1. Replies: 1
    Last Post: 11-06-2018, 11:03 AM
  2. Notifications aren't coming through from my contacts
    Last Post: 11-06-2018, 11:02 AM
  3. Anyone knows ehat is the memory card-like icon on my notification bar?
  4. Where did my flashlight go??
    Last Post: 11-06-2018, 05:37 AM
  5. Replies: 1
    Last Post: 11-06-2018, 05:35 AM
