    I did the volume down, home, power button and it went black and then pop-up back same problem with this... ODIN blue screen... I have Samsung Note 5 and I purchased 3 years ago... Can you solve the problem... Thanks...
    08-03-2019 03:05 PM
  2. mustang7757's Avatar
    Hi , if you can register a account here , me or other members be happy to assist.
    I'll provide a link to register so you can communicate here.https://forums.androidcentral.com/as...community.html
    08-03-2019 03:14 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you referring to another thread? You mentioned "same problem with this."
    Does anything happen at all when you try to boot into Recovery Mode? If not, then either the battery or the motherboard is faulty.
    08-03-2019 04:10 PM
  1. Where is the Pie update?!
    By milleniumdroid in forum Samsung Galaxy Tab S3
    Last Post: 08-21-2019, 12:22 PM
  2. htc 10 stuck in no service mode
    Last Post: 08-03-2019, 05:01 PM
  3. Why is my Samsung galaxy showinget H+ instead of 4g.I'm on voxi from Vodafone
    Last Post: 08-03-2019, 04:57 PM
  4. Replies: 2
    Last Post: 08-03-2019, 04:56 PM
  5. Why cant i go into recovery mode on android oreo
    By Android Central Question in forum Android 8.0 Oreo
    Last Post: 08-03-2019, 03:48 PM
